Hi, I'm sorry if this has already been asked.
My clutch bite point is just off the floor.
I tried bleeding the system (2 man method), however every time the pedal was pushed to the floor it would stick and have to be pulled up and then pumped (5-6 pumps)repeatedly until it went 'hard', otherwise it would just drop back to the floor, this happened for every iteration.
I have completely changed the fluid and the bite point is still in the same place, there is no visible leaks anywhere.
Could this be a master/slave cylinder problem.
Thanks in advance
I30 CRDI CW 2008 (Estate)
