Thanks for your feedback is it a big job just i have removed the door card and all bolts but there is something holding it in and didnt want to pull to hard
Remove the external door handle. In the door end, there's a rubber plug, remove that, then you'll see a bolt, could be 8 or 10mm, undo that and that will allow the handle end cap to be removed, coan't remember if there's another bolt but the handle then slide in a short sharp motion toward the cap end and remove. Now that's removed the rest of it internally can come out
