Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
April 19, 2024, 06:24:26
GOT PROBLEMS OR ISSUES?
PETROL
Loss of power
Loss of power
Philt75
7 ·
9030
« previous
next »
Print
Pages:
1
Go Down
Philt75
1st Gear
3
Wales
Loss of power
June 12, 2021, 20:55:41
I30 petrol, manual 1.4L
Mileage 126000
The issue started in 2020 with it loosing power and the engine management light came on but would then go out when you hit about 3000 revs.
Put it into a garage and they changed the spark plugs which improved the issue but did not fully fix the issue.
Since then the car has a lumpy idle and when changing gear the car seems to go into limp mode for a second or two and then goes back to normal. Occasionally when this happens the engine light flashes for a few seconds.
The power of the car is a lot less than it used to be
I have had this checked by a garage and they said that they could not find anything.
So I had the car fully serviced by hyndai which cost me £1200 and for 2 weeks the car felt great then it went back to how it has been for the past year. Before I start shelling out yet more money I thought I would see if anyone has any ideas as to what it could be. I'm at the point where I am going to get rid of the car if I do not sort this soon.
Any help would be really appreciate.
Phil
Own
Admin
43,330
England
Re: Loss of power
Reply #1: June 12, 2021, 21:24:33
Hi
Philt75
and
Do you use the same filling station for your fuel? Just wondering if a change of supplier might make a difference...
Ioniq MY2018 SE Premium Hybrid in Polar White with added oomph
eye30
Global Moderator
HOS BOSS
27,352
England
Wirral, UK. - 1.4 Petrol Active - Aqua Blue
Re: Loss of power
Reply #2: June 13, 2021, 12:07:41
At the service did it include a check of the fuel filter which for petrol is in the tank under rear seat.
At one of my services hy ticked filter checked but i said hadn't.
They said yes it had so I asked to prove it.
The chap lifted the rear seat and said thry had taken the fuel tank inspection lid off.
I asked how did they do that when the carpet was still in one piece as the cut out was still attached.
I rest my case!!!
1.4 Petrol Active I'm no expert, so please correct me if
Aye30
3rd Gear
167
Australia
Re: Loss of power
Reply #3: June 13, 2021, 14:47:26
If the engine management light flashed, there should be an historic code logged in the computer. A cheap obd2 reader should be able to read and pinpoint the area of concern. Is this a coil on plug engine or does it have leads to the plugs? and what did they charge you for in the 1200 pound service?
Philt75
1st Gear
3
Wales
Re: Loss of power
Reply #4: June 14, 2021, 17:00:32
Hi guys,
Thanks for the info.
I have had the engine plugged into a diagnostic machine but the garage said that nothing came up (that is if they bothered to do it) I will get it checked again.
The £1200 was for loads of things including breaks, tyres, shocks, springs etc. Begining to think it would have been better to upgrade it to a newer version.
Own
Philt75
1st Gear
3
Wales
Re: Loss of power
Reply #5: July 19, 2021, 14:18:13
Hi guys and gals
Well I finally found out what the problem is. The pressure in the fourth cylinder is down. Unfortunately it will cost to much to fix.
Thanks for everyone's help.
Own
sundiz
Technical Advisor
827
Finland
Re: Loss of power
Reply #6: July 19, 2021, 15:22:41
Shame.
Sometimes these codes disappear when engine gets restarted and can be difficult to diagnose. When car goes in to limp mode it would be good to check the codes before shutting the engine. I've managed to find couple of mystery codes with that method. May be difficult if you don't have own obd reader.
i30 cw 1.6crdi -08
Print
Pages:
1
Go Up
PETROL
Loss of power
Search
Username
Password
Always stay logged in
Forgot your password?
