Squeak/squeal- bearings?
Npmr · 3 · 8744
Offline Npmr
Hi
I would really appreciate any help or advice on this...
My UK 2016 i30  makes a squeaking/squealing sound as the wheels rotate but only after driving for some time eg 1/2 hour,  and after coming down a very steep hill! It usually persists for some time after this.
I have had brakes and pads replaced but it was there before and after this work, although it is slightly higher-pitched now and appears more noticeable when reversing. I had taken the car in to the dealer but they couldn't find anything obvious and the sound wasn't there when they had the car.
 I have tried to video it and you can hear the sound -kind of chirping in forwards and more metallic in reverse (although slightly muffled by the ambient sounds of driving with the windows open)- YouTube links:
It doesn't seem to change when braking so I think its something to do with the wheels/rotation/bearings...
Any ideas and thoughts of how to confirm what the issue is?
many thanks
Offline Npmr
* update!
After driving for a few hundred miles more I can say that the noise does seem to stop when the brakes are used, even lightly.
Tried to listen videos, but my audio or my hearing is so bad that I did not hear a thing. If possible lift one corner up and try to wiggle the lifted tyre.
