The i30 Owners Club
Limp mode sorta problem.
Mazt3r · 11 · 922
Offline Mazt3r
Hi guys  :goodjob2:
New here on the forum however long time lurker.
Forgive me if this problem has been asked before but I'm a little frustrated.
So i have a 2015 Hyundai i30 1.6 crdi, great great car. However. The other day when i was on my way home i turned a corner and went into a sort of limp mode, i say sort of because it gets limited to 4000rpm, and not 3000rpm as i have seen mentioned Alot on this forum.
I had a tester on it and it said i had a p0101 (mass airflow sensor) and a p0113 (IAT Sensor problem) i thought ok and went to look at them. The mass airflow sensor is clean as a whistle same with the air filter. And after some searching i found that the two units are probably built together. Anyhow i erased the codes and started the car up. No new codes but still no power at all and limp mode activated.
I then disconnected the batteri for an hour because this has worked on other cars. But to no success. I then took it for a drive while getting live data from the obd port.
The IAT reads the temperatur pretty close to outside temps.
And the mass airflow sensor is at 8-9 grams in idle.
Still i can't get out of limp mode.
Any suggestions would be enormously appreciated.
  :crazy1:
« Last Edit: May 29, 2022, 22:36:18 by Mazt3r »
  • Hyundai i30 1.6 crdi 2015. Kia optima 1.7 turbo diesel 2016.
Offline PiL
  • Lord and Master
      Sydney, NSW
  • Pump it Loud
Try checking the fuel filter.
Had this issue and that was the cause.
Couldn't get it to work so disabled it.
  • GDe i30 tourer elite diesel
Offline Mazt3r
Ok I'll try that. Disabled it how do you mean ?? And thank you
Offline PiL
  • Lord and Master
      Sydney, NSW
  • Pump it Loud
Offline Mazt3r
Thank you so very much ordered a new filter today I'll update when i figured out how to prime it and when it is changed but again thank you  :goodjob:
Offline Mazt3r
Update time. And it's not good.  :crazy1:
I changed the mass airflow sensor and the fuel filter but absolutely nothing has changed. I'm still Limited to 4k rpm and i have no power at all. I hear no turbo spool and engine load is 100% almost as soon as I hit the gas.
Anybody got any advice ?  :crazy2:
Offline Mazt3r
So even more news. I had a buddy connect his obd computer today from a mechanic bigger than the one I got. He found a nox sensor error in the particle filter. And the intake house after the turbo gets sucked flat is if there is vacuum in there. From this I'll guess that either particle filter is fully clogged or turbo has gone.
Offline Mazt3r
I think I found the problem.
Today when i removed the IAT Sensor everything is covered in soot i think maybe the intake manifold is completely clogged and that the car can't breathe. I'll take it in to get cleaned maybe tomorrow
Offline Mazt3r
Update. So this is weird.
I have had no codes thrown by the car for a long time. Took it to a mechanic. His diagnosis. Intercooler full of half a litre of oil so he thinks it's a blown/stuck turbo.
Just think it's weird i get no codes from that.
Should i believe him and get the turbo changed or should I question it.  I'm a little at a loss.
Are you able to verify the oil is there? That would be a start in trust.
Offline Mazt3r
I agree. I'm gonna take it to where i bought it and get a second opinion there. Just a shame. A new turbo fitted is gonna be $2-3k
