Air con compressor issues
william · 13 · 3673
Offline william
      Victoria
I rarely get to drive the wife's car but noticed the air-con compressor on its way or might have to be re gassed or possible leak. Turn it on and it takes a while to charge with a noise like a slow whooshing noise.
  • i30 wagon 09
Is that the car wit 400K + on it?
Offline william
      Victoria
Yep 426500km still drives like its brand new
  • i30 wagon 09
Cheers.. so it's done well then. I reckon I'll need a re-gas before then...
Offline DragOn
      Western Australia
Does it have vacuum controlled air vents/flaps. Might be them moving around when you activate the external air/recirculation or face/feet options.
  • i30 GD 5 Door Hatch 1.8l Auto Silver | '74 4 Door Torana | '09 FD Manual 2.0l
The whooshing sound will be the refrigerant oil passing through the pipes without the correct amount of gas due to a leak, you wont or shouldn't re-gas the system until the leak is found and repaired.
Offline william
      Victoria
Only happens when you push the AC button . I've got a auto refridgy mechanic coming to pressure test it. And I'll go from there gotta keep the wife happy  :whistler:
  • i30 wagon 09
Stands to reason that the aircon has to be on :)
Yes pressure test is the first step, once the leak is found and fixed then it can be re-gassed, fingers crossed it's an external seal or valve :fingers:
Offline william
      Victoria
Got it tested no leaks still heaps of gas but said there's an electrical fault in the compressor. Anyone here of that ?
  • i30 wagon 09
Sounds like it might then be the connection to "or" the actuators for the valves and swash plate, valve issues would explain the swooshing sound.
Offline william
      Victoria
Sounds expensive I don't think I can fix it myself ! :crazy2:
  • i30 wagon 09
I'm unsure of costs or maintenance procedures for auto compressors, I'm more familiar with domestic refrigeration.
I'd ask for a quote to fix first if possible :undecided: second hand compressors can be bought through ebay/wreckers from $165 - $220 but then you'll need someone to evacuate the system and re-gas when fitted.
