Low (FOB) Key Battery message
TerryT · 37 · 20297
Offline wooly
      Tasmania
checked both old batteries with a dry cell tester that applies some load. One battery was at 10% (2.06V) capacity, the other battery was 70% (2.62V)
Changed the battery this afternoon and checked the old one on a load tester and it initially showed 2.65v and dropped fairly quickly to 2.6v so I concluded that it is indeed rooted.
The new one measured 3.3v unloaded before I put it in, but I doubt it would stay like that for long.
Also cleaned the contacts in the clip assembly with isopropanol and a cotton bud for good measure.
The short battery lfe surprised me because my 20 year old Corolla still had the original battery in the fob when I sold it.
Thanks go to TerryT for an excellent diy guide to doing this without breaking something.
Offline Greyhound
If you have the time, please let us know how you went.  Maybe a picture or two if the process is markedly different from the video?
I have no need to change battery just yet, just wanted to know how to do it in advance of when the time comes.
Yes I will post again if I can add more information to ths thread.
  • i30 PD 2020 1.0 T-GDi
Online TerryT
      Sydney, NSW
@ Greyhound, ok, thanks, I understand.
Online TerryT
      Sydney, NSW
"...it is indeed rooted."  I try to avoid using technical terms. :wink:
 Glad my guide was useful.
Online TerryT
      Sydney, NSW
Below are two photos to help better illustrate Step 7 of my guide at post #290 of 4 August 2021.  I forgot to include them and cannot modify my original post to add them. :-[
Step 7 (Modified)
(a) First, mate together the two ends of the fob (#1).  Use the thin lip on the case end to wedge into the other half.
(b) Firmly press the halves together in order #1~#3 until the halves click into place.
Offline Greyhound
OK I have finally been forced to change my flip-key fob battery as opening and closing the car had become troublesome.
I attach 3 photos which should be self explanitory. Just go easy working the case apart and don't go straight in with a flat head screwdriver or you will likely damage the plastic. You can carefully use a flat head once you have made initial separation. Enjoy.
EDIT: by the way I measured the old CR2032 battery voltage using my DVM and it was 3.0V. But even at that voltage the door open function was playing up.
« Last Edit: September 04, 2021, 15:56:22 by Greyhound »
Online TerryT
      Sydney, NSW
@ Greyhound.  Thanks for posting (above) your fob battery replacement guide, will be helpful for those with that style of key fob.
