2009 I30 headlight problem
Offline clutter66
      Queensland
Hi all, hoping someone may be able to help.  I've got an issue where none of the lights in the RH headlight assembly work.  I've checked the bulbs and replaced a few just to check and nothing works.  So in short, no high or low beam, no parker and no indicator.  The right hand indicators flash rapidly indicating a faulty bulb bit it's new, couldn't see an issue with the old one either.  Have swapped the relays over and no change and also swapped the fuses out and no change, fuse in cab is fine too.  I ran out of light to check if I had power but was thinking it may be an earth problem.  Any ideas?  Thanks for any responses.
Cheers,
Mick
  • I30
Online The Gonz
Could be a loose cluster connector. The indicator racing supports the idea because the healthy bulb would appear open-circuit if the connector is loose.
