UK Vehicle Safety Recalls - Jan to March 2018
AlanHo · 4 · 2024
Vehicle safety recalls: January, February and March 2018 U.K
These are the vehicles, parts or accessories recalled by manufacturers for a safety reason during January, February and March 2018.
You can check for vehicle, part or accessory recalls or find out more about vehicle recalls and faults.
DVSA reference number   Make and model   Issue
R/2017/277   Merecedes-Benz: Arocs 964 Positive battery cable may have been incorrectly fitted
R/2017/296   Merecedes-Benz: Arocs 964    Parking brake may not function as intended
R/2017/314   Mercedes-Benz: Atego 967, Atego II   Rear axles may leak oil
R/2017/316   Mercedes-Benz: Citan    Seat belt securing bolts may not be correctly tightened.
R/2017/323   Mercedes-Benz: Vito    Retaining ring of the front bearing may be incorrectly located
R/2017/324   Mercedes-Benz: V-Class   Retaining ring of the front bearing may be incorrectly located
R/2017/327   Mazda: Mazda 6    Corrosion may form around the parking brake actuating shaft and cause reduced handbrake performance
R/2017/329   Toyota: Avensis, RAV4   Bolts on the exhaust side of the turbocharger assembly may be incorrectly tightened
R/2017/330   Scania: P, G, R and S Series   Wheel may fracture
R/2017/331   Vauxhall: Movano B   Diesel filter securing strap may break
R/2017/332   Lexus:  CT200h   Possibility of a fuel leak
R/2017/333   VW: Amarok   Power steering return hose can become damaged and cause hydraulic fluid to leak and/or the power steering to fail
R/2017/334   Audi: A4, A5, A5 Cabriolet and Q5   Auxiliary heater element in air conditioning may fail and/or overheat
R/2017/335   Wrightbus: NBfL / NRM   Rear door may malfunction
R/2017/336   Peugeot: 3,008   Fuel may leak
R/2017/337   Bugatti: Chiron   Backrest frame of driver and passenger seats may be welded incorrectly
R/2017/338   Mercedes-Benz: E-Class   Seatbelt pretensioner may not operate
R/2017/339   Citroen: C3, C3 AIRCROSS, C4, DS3, DS4, DS5, C4 PICASSO, BERLINGO, BERLINGO VU   Engine component  may not be to specification
R/2017/340   Peugeot: 208, 2008,301, 308(T9), 3008, 5008, 508, PARTNER TEPEE(B9), PARTNER VU   Engine component  may not be to specification
R/2017/342   Mercedes-Benz: AMG GT/GTS   Passenger seat occupancy sensing system  may malfunction
R/2017/343   Aston Martin: DB9, DBS, Vanquish, Virage   Movement of seat may damage battery supply cable
R/2017/344   VW: T6 Van   Fuel hoses may crack and leak
R/2017/345   Aston Martin: DB9, DBS, Rapide, Vanquish, Virage   Vehicle may roll away
R/2017/346   VW: T6 Car Variant   Fuel hoses may crack and leak
R/2017/347   VW: Polo   Towing eye in the vehicle tool kit  may detach during use
R/2017/348   Skoda: Citigo   Towing eye in the vehicle tool kit  may detach during use
R/2018/001   Scania: Trucks with AS903 tag axle   Hub nut may not be tightened to correct torque
R/2018/002   Citroen: Spacetourer, Dispatch IV – DV6FC Engine   Engine component  may not be to specification
R/2018/003   Peugeot: Traveller and Expert 4 DV6F Engine   Engine component  may not be to specification
R/2018/004   Volvo Bus: B5LH(3)   Starter motor heatshield may break off and cause an electrical short circuit
R/2018/005   SEAT: Mii   Towing eye may be defetcive
R/2018/008   Ford: Kuga, Focus, C-Max, Fiesta ST   The engine cylinder head may  crack
R/2018/009   Ford: Transit Connect   The engine cylinder head may  crack
R/2018/016   Skoda: Karoq   A-pillar passenger protection trims may peel off in sub-zero temperatures
R/2018/017   Mazda: Mazda2   Handbrake may disengage unexpectedly
RM/2017/038   Peugeot Scooters: Kisbee Streetzone   Frame may crack
RM/2017/039   Aprilia: RSV4 Euro, RSV4 Euro 4, Tuono 1100 Euro 4   Reduced brake efficiency
RSPV/2017/018   Can-Am: Outlander, Outlander MAX   DPS shaft may break causing a loss of steering control
R/2018/010   Mercedes-Benz: C-Class, S-Class, E-Class Coupe, GLC   Front seat belt tensioners may not function
R/2018/014   Mazda: RX-8   Fuel may leak
R/2018/015   Mazda: RX-8   Front lower suspension  arm ball joint casting may crack / break
R/2018/020   Mercedes-Benz: A-Class   Bonding of the windshield may be inadequate
R/2018/022   Maserati: Ghibli and Quattroporte   Fuel line may leak
R/2018/023   Aston Martin: DB11 V12, DB11 V8   Inadvertant airbag deployment
R/2018/024   Renault: Clio IV   Central hinge in rear seats may fail under load
R/2018/025   Renault: Zoe   Incorrect throttle pedal fitted
R/2018/028   Maserati: Quattroporte   Loss of engine power
R/2018/031   VW: Golf   Passenger airbag may not deploy as intended
R/2018/032   SEAT: Alhambra   Passenger airbag may not deploy as intended
RM/2018/001   Ducati: Scrambler MY2017-2018, Multistrada1200 and 1260, Monster, XDiavel and Panigale   The floating piston in the front brake master cylinder may crack
RM/2018/002   Indian Motorcycles: Roadmaster   Water may enter rear light wiring harness and cause corrosion
RM/2018/003   MV Augusta: F4 RR, F4 RC   The floating piston in the front brake master cylinder may crack
RM/2018/004   Triumph: Thruxton (various models)   Engine may stall
RSPV/2018/001   John Deere: GATOR XUV825 range   Steering may fail
R/2018/011   Ford: Focus, C-MAX   Casting defect may cause alloy wheel(s) to crack
R/2018/026   Fiat: 500   Instrument cluster may display incorrect information
R/2018/034   VW: Passat CC, Sharan   Passenger airbag may not deploy as intended
R/2018/039   Ford: Fiesta   Brake servo may fail
R/2018/040   Audi: A3   Passenger airbag may not deploy as intended
R/2018/041   Skoda: Octavia   Passenger airbag may not deploy as intended
R/2018/043   Audi: Q5   Passenger airbag may not deploy as intended
R/2018/044   Audi: Q3   Passenger airbag may not deploy as intended
R/2018/045   Nissan: NV400   Fuel filter support may break
R/2018/046   Mercedes-Benz: GLE   Bonding of the windshield may be inadequate
R/2018/047   Mercedes-Benz: E-Class   Catalytic converter support bracket may be insecure
R/2018/048   Peugeot: 308(T9), 3008,5008, 508   Engine may overheat
R/2018/049   Citroen: C4 PICASSO, C4,  C5, DS5   Engine may overheat
R/2018/051   Audi: A4, A5, Q5   Auxilliary heater element in air conditioning may fail and/or overheat
R/2018/054   Mercedes-Benz Bus: Tourismo   Driver's door panel may detach
R/2018/056   Volvo Truck: FH, FM 4   Driver's  airbag may not deploy as intended
R/2018/057   Tesla: Model S   Passenger airbag may not deploy as intended
R/2018/060   SEAT: Ibiza, Leon, Altea, Alhambra   Starter motor may malfunction and overheat
R/2018/061   Audi: A3   Starter motor may malfunction and overheat
R/2018/062   VW: Beetle, Eos, Golf, Jetta, Passat, Scirocco, Sharan, Tiguan, Touran   Starter motor may malfunction and overheat
R/2018/063   Vauxhall: Movano B   Steering column joint may not be secure
R/2018/064   VW: T6 - Van   Replace front passenger airbag
R/2018/065   VW: T6 - Car   Replace front passenger airbag
R/2018/066   VW: T-ROC   Key information about passenger protection systems is not included in owner's manual
R/2018/067   Mercedes-Benz: AMG GT R   Roll bar configuration does not meet legal requirements
R/2018/071   Suzuki: Baleno, Swift, Ignis   Battery may fail to charge which could cause engine to stall and lights to fade
R/2018/072   Evobus: Citaro   Connection in fuse box may be insecure
R/2018/073   BMW: X3   Rear spoiler may be insecure
R/2018/074   VW: Golf, Tiguan   Front brake discs may not be correct thickness
R/2018/075   Nissan: NV400   Steering column joint may not be secure
R/2018/076   Dacia: Logan   Front wheel hubs may crack
R/2018/077   Renault: Zoe   Front wheel hubs may crack
R/2018/078   Suzuki: Baleno, Swift, Ignis   Integrated starter generator  belt belt may fail
R/2018/079   Renault: Master   Steering column joint may not be secure
R/2018/083   Volvo Bus: B5LH, B5LH(3), B5TL(3) & B8RLE(3)   Loss of power assistance to steering
RM/2018/005   Husqvarna: F450   The floating piston in the front brake master cylinder may crack
RM/2018/006   KTM: 1290 Super Duke, 690 Duke   The floating piston in the front brake master cylinder may crack
RM/2018/007   Kawasaki: ZX1000S,(NinjaZX-10R) and ZX1000Z Ninja ZX-10RR   Transmission may fail
RM/2018/008   Suzuki: GSX-R1000/R L7, L8   Drive chain may stretch, come off or break
RM/2018/009   KTM: 690 Duke, 690 Duke R   Fuel may leak from tank filler nozzle
RM/2018/011   Harley-Davidson: Touring, CVO, VRSC   Potential loss of brake function on  bikes fitted with ABS
Very subtle Mr Ho...
Plenty of Mercs and other so called upmarket cars in that lot, but Hyundai and Kia conspicuous by their absence...  :whistler:
 :happydance: :happydance: :victory: :mrgreen:
Offline Joewong
   :Shocked: :lol:
  • 2017 i30 Active PD 2.0-litre Auto Phantom Black
   :Shocked: :lol:
Reminds me of the old Rolls Canhardly...
Rolls down hills, can hardly get back up again... :evil:
