Replacing the crank shaft sensor
yodm · 31 · 9001
Offline yodm
    • il Israel
      Israel
this brings me the my next question. how to replace the sensor and if anyone have the pn of the sensor
  • I30 CW 2010 1.6 petrol auto
hopefully I got it right, 1.6 petrol
391802B000
should be  easy to replace once you locate where it is which maybe on the top or in the  of the flywheel housing. I have diesel so I know mine is at the rear on top but petrol not 100% sure.
Someone else can confirm but it'll be a single 10mm bolt holding it on then undo the harness.
Offline yodm
    • il Israel
      Israel
so it should be very easy to replace. just need to find the location.
Offline yodm
    • il Israel
      Israel
is this the crank shaft sensor?
Offline yodm
    • il Israel
      Israel
I am sorry, I don't speak Ausy
could you please put it in world wide words?
I was being a bit cheeky. Engine seems very dirty!
Thanks for taking the time to take some photos and post them by the way!  :goodjob:
Offline yodm
    • il Israel
      Israel
actually, I was asking if this is the crank shaft sensor.  :question:
yes, the engine bay is pretty dirty. we have a lot of dust here, and the rain get all the road grime to the engine bay.
on my Citroen, that I bought new, I used to clean the engine bay every time I washed the car. for about 4 years now I don't (wash the car  :crazy1:)
the I30, I bought a couple of months ago and I did not wash it yet.
If you're pointing to only to the same location in both photos and being an Auto box, NO.  That's the output shaft speed sensor.
you can see it has a connector and no fly lead. In that image  I put up the whole part has the sensor and a fly lead attached.
what motor is this again?
I have the diesel but I'd be looking on the engine side, from the very top where the engine butts up to the transmission bellhousing and make your way forward of the engine.
May even be at the front but it'll be to the right side very close to the joints I suspect. I'll see if I can google an image somehow as I've never seen the petrol engine.
It was 2am and I had a lousy sleep... Lucky I didn't put the actual words...  :P
I'm reading it's attached to the gearbox. This image is not great out of the manual but I'm thinking it's running off the flywheel or in this case the flex plate.
"This sensor is installed on transaxle housing "
You should be able to spot a thick cable like this with all that spirax and it's clipped most likely to a bracket at the front
Offline cruiserfied
  • Crooked-H Hero
Close. Not on the transmission, sensor reads off a tone wheel slightly forward of rear main bearing.
thanks. sure makes it hard when you've never seen one. I know where mine is, only had what the manual said to go by but other images suggested in the engine.
I hope when the OP finds he takes a snapshot and posts it for educational purposes :)
Offline yodm
    • il Israel
      Israel
the second diagram seems like my engine, petrol 1.6 126 hp,
so I was looking at the rear of the engine when it is located in the front of the engine
Mate ,  I reckon the harness itself should be identifiable. Do us a favour and take some pics when you find it. Curiosity is killing me.
Offline yodm
    • il Israel
      Israel
Wow! Not being rude, but that looks to be a very ducking fusty engine bay!  :Shocked:
well I hope thus is better ( going off topic here  :head_butt:)
 :crazy1: :crazy1: :crazy1:
this was my primary car until the wife finely got a job.
now this is the wifes car.
after almost 10 years with Citroen C4 (2 generations), when trying to lift the hood, I keep thinking to myself " who screwed the hood to the body????"  :Jaw:
10 years with aluminum hood will make you go like that when trying to lift a normal hood....
certainly different but the only thing I spot is the colour of the "coolant" in the radiator tank. ? Looks very rusty in there or is that a red coolant type
Wow! it is a dusty place!  :Shocked:
I quite like the quirkiness of French cars! Although in Australia they have a poor reputation for reliability in recent years and resale value can also be a worry. I had a Renault for 4 years (1978-82) and still have fond memories.  :goodjob:
Offline yodm
    • il Israel
      Israel
TW, rest assure that the coolant is in good condition.
its not red, its something else, spacial Citroen coolant.
No worries  :D
So how is project crank sensor going? Have you located it yet?
Offline yodm
    • il Israel
      Israel
as I go out before 6 AM and comes back after 10PM, it is pretty difficult to find the time.
hopefully this weekend.
Quote from: yodm
... I go out before 6 AM and comes back after 10PM ...
Is your car really that bad? :eek:
Offline yodm
    • il Israel
      Israel
 :rofl:
Shambles, its not because of the car, its because of my work.
the car runs fine most of the time, from time to time it stalls.
Offline yodm
    • il Israel
      Israel
391802B000
this is the correct part for the 1.6 petrol 126 hp engine
I could see the connector but the sensor can only be reached from below the car.
I went to a place that had good recommendations, he put the car on the lift and 5 minutes later the car was out.
 :goodjob:
Offline yodm
    • il Israel
      Israel
here are some pics.
lots of dust so the pics are not very clear  :gotcha:
need to lift the car in order to get to the sensor
Pictures not showing for me
Offline yodm
    • il Israel
      Israel
for some reason, it takes a couple of hours for the link to work.
