Did you check the tyres soon after driving back from the service? They could have been hot and appear over-inflated.
Johnanother reason I haven't used a dealership for some time,I also mark my filter oil filter case,engrave my initials on the fuel filte rim(top where you can get to)I've caught three dealerships out for charging what they have not done
Checked my tyre pressures after having my i30 serviced and found all tyres at 44 psi. Was also told tyres were nearly illegal and when checking the fronts had slight wear on the edges but looked like a new tyre across the face . Normally keep pressure about 37psi owing to many roundabouts in my area but never as high as 44psi. Used a local tyre retailer to rotate the wheels & balance for $20 who told me tyres were fine. Dealer wanted to to do it for $45 and were more than likely trying to sell me new tyres. :roll eyes: Car has only 12.275 km on it.
Hi johnb,Our i has 11500 on it , just about to rotate. Good, even wear on all 4.Can't see how yours could be dead. They are NEXEN , usually run at 36 but noted max psi is 41. Took them to 40 the other day . Definitely stiffer. So yours isn't that much higherIsn't edge wear a sign of under inflation? .
Quote from: John B on May 11, 2017, 08:36:54Checked my tyre pressures after having my i30 serviced and found all tyres at 44 psi. Was also told tyres were nearly illegal and when checking the fronts had slight wear on the edges but looked like a new tyre across the face . Normally keep pressure about 37psi owing to many roundabouts in my area but never as high as 44psi. Used a local tyre retailer to rotate the wheels & balance for $20 who told me tyres were fine. Dealer wanted to to do it for $45 and were more than likely trying to sell me new tyres. :roll eyes: Car has only 12.275 km on it. So the dealership told you the tyres were nearly illegal after only 12000kms ??? is that right
Quote from: joebris on May 11, 2017, 21:15:06Quote from: John B on May 11, 2017, 08:36:54Checked my tyre pressures after having my i30 serviced and found all tyres at 44 psi. Was also told tyres were nearly illegal and when checking the fronts had slight wear on the edges but looked like a new tyre across the face . Normally keep pressure about 37psi owing to many roundabouts in my area but never as high as 44psi. Used a local tyre retailer to rotate the wheels & balance for $20 who told me tyres were fine. Dealer wanted to to do it for $45 and were more than likely trying to sell me new tyres. :roll eyes: Car has only 12.275 km on it. So the dealership told you the tyres were nearly illegal after only 12000kms ??? is that rightHi joebris, Yes that is correct 12270km on the clock and told me they were on the verge of illegal and I should get them sorted out sooner than later. Told them in no uncertain terms what a load of crap.
Quote from: John B on May 12, 2017, 01:29:15Quote from: joebris on May 11, 2017, 21:15:06Quote from: John B on May 11, 2017, 08:36:54Checked my tyre pressures after having my i30 serviced and found all tyres at 44 psi. Was also told tyres were nearly illegal and when checking the fronts had slight wear on the edges but looked like a new tyre across the face . Normally keep pressure about 37psi owing to many roundabouts in my area but never as high as 44psi. Used a local tyre retailer to rotate the wheels & balance for $20 who told me tyres were fine. Dealer wanted to to do it for $45 and were more than likely trying to sell me new tyres. :roll eyes: Car has only 12.275 km on it. So the dealership told you the tyres were nearly illegal after only 12000kms ??? is that rightHi joebris, Yes that is correct 12270km on the clock and told me they were on the verge of illegal and I should get them sorted out sooner than later. Told them in no uncertain terms what a load of crap.@John B Any chance you could post up a pic of the tyre?
OK. Thanks JB.Yep. Certainly legal for some time yet.I would be running them at as high a pressure as you're comfortable with though.That's a pretty savage shoulder wear. You're certainly correct about roundabouts. They're wonderful for traffic flow and a nightmare for tyre wear.Just a word of caution about that type of wear.When cornering, whether on a roundabout or just turning, with sidewall flex, a significant portion of the car's weight is concentrated on that outside shoulder. The good tread will only just be in contact with the road.Which means, especially in the wet,you may not have a lot of grip, because the tread that's doing all the work is pretty worn.
Quote from: Surferdude on May 12, 2017, 04:32:01OK. Thanks JB.Yep. Certainly legal for some time yet.I would be running them at as high a pressure as you're comfortable with though.That's a pretty savage shoulder wear. You're certainly correct about roundabouts. They're wonderful for traffic flow and a nightmare for tyre wear.Just a word of caution about that type of wear.When cornering, whether on a roundabout or just turning, with sidewall flex, a significant portion of the car's weight is concentrated on that outside shoulder. The good tread will only just be in contact with the road.Which means, especially in the wet,you may not have a lot of grip, because the tread that's doing all the work is pretty worn.Thank's Surferdude, appreciate your advice. I will run them at 40psi and see how I will go. I am a pretty sedate driver so their will be no fast cornering for me, in fact I might stick my foot out when cornering The dealer told me the cause of the wear was because I went around the roundabouts to slow. The strange thing is my daughter has a i30 same age as mine but double the kms with Hankook tyres that have no noticeable wear at all, go figure .
@ Surferdude. Sure did make sense, your virtually saying cut out the roll. Did think of another way to achieve it ( go straight across the roundabout ) Seriously though I will try what you suggested. Going down to the local shops from where I live there are 9 roundabouts so 18 there and back !!! Just one question how come as I have mentioned, my Daughter has done twice the kms lives in the same estate and has no wear on her Hankook tyres that I have kept to the same 37 psi as mine ? Are Hankooks known to wear better than Nexen's ?
I'm a committed 41er all 'round for a nice flat treadface.
