The i30 Owners Club
GOT PROBLEMS OR ISSUES? => DIESEL => Topic started by: chris_i30gd on September 09, 2017, 14:37:52
Title: temperature checking - i30 gd diesel
Post by: chris_i30gd on September 09, 2017, 14:37:52
I recently changed oil in my i30 diesel 1.4 crdi 2013 model and I added  liqui moly ceramic  additive.
This one:  :link: Liqui Moly Ceratec Engine Oil Additive Ceramic Wear Protection 3721 5 pack | eBay (http://www.ebay.com/itm/Liqui-Moly-Ceratec-Engine-Oil-Additive-Ceramic-Wear-Protection-3721-5-pack-/171639723408)
After 500km of use and a short 200km trip that  I have done today
the  temperature was  1 line under 90C degrees and has 5 lines in gauge when I arrived.
(https://i.imgur.com/RwMDVa8.jpg)
I forgot If I had 5 or 6 lines temperature before. Can you inform me your temp gauge info :)
Thanks!
Title: Re: oil temperature checking - i30 gd diesel
Post by: Shambles on September 09, 2017, 14:44:24
Mine is always 5 bars when hot.
Title: Re: temperature checking - i30 gd diesel
Post by: chris_i30gd on September 09, 2017, 14:51:15
yes - so its 5 bars the normal ok thanks!
Post by: guest9517 on September 10, 2017, 13:05:45
5 Bars in dash, 87-94 C on Eobd while driving
Post by: mickd on September 10, 2017, 23:21:19
Oil temp should be about the same as engine temp - 90 deg C.
Most thermostat 's are 90 deg C.
Yes /No ?
Post by: guest9517 on September 11, 2017, 05:55:31
Typically my engine oil temp. is 10-15 C lower than coolant when at speed after 40-50 Km of driving (15-20 C outside temp)
Post by: chris_i30gd on September 11, 2017, 10:34:52
By the way liqui moly oil + ceramic additive has reduced the diesel engine noise. It sounds almost like petrol
Post by: The Gonz on September 12, 2017, 06:18:51
I'm attracted to reducing the Diesel clackers but the temperature detail is unclear to an FD driver. Did the additive change the temperature?
Post by: chris_i30gd on September 12, 2017, 16:14:42
I haven't measure the Temperature of engine and oil.
But the engine noise is reduced and I can hear it working better.
Also if you search online for reviews about this company's additive products
they have great reviews for all.
