The i30 Owners Club
GOT PROBLEMS OR ISSUES? => DIESEL => Topic started by: coolbzk on February 13, 2018, 18:17:08
Title: 2009 i30 Diesel eps/esp off light are on
Post by: coolbzk on February 13, 2018, 18:17:08
Hi all,
recently i noticed my steering wheel started to clunk and knocking when it passes the center, after i googled it, it seems the common problem for i30 due to a rubber bush corruption in steering motor,
so i checked with my mechanician and he said he will do some home work first.
then since last Saturday , both eps and esp off lights are on on my dash, the eps still works as the wheel is not that heavy, i called hyundai dealer and they said if it is a rubber bush problem, the eps light should not be on, and recommended me to drive in and diagnose first. if it is a steering column problem it will cost me around 4k Australia dollar  to replace it.
my mechanician also called me back saying hyundai should have a recall for this , so i called hyundai customer service with my vin number, but they said my car is not in the recall list .
i have eps off related brake switch recall in 2013, but both hyundai customer service and dealer have checked my vin and said my car is not valid for mdps recall  :link: Hyundai?Hyundai Elantra (HD) & i30 (FD) MDPS | Product Safety Australia (https://www.productsafety.gov.au/recall/hyundai-hyundai-elantra-hd-i30-fd-mdps)
the symptom looks the same.
i am not sure if i can do the rubber bush replacement by myself in worst case(hyundai refused to recall and asking 4k to fix it), my car is valued at 8k i think , i definitely not going to pay 4k to fix it.
any doc for how to dismount the steering motor without taking the steering wheel off ?
Much appreciated!
Title: Re: 2009 i30 Diesel eps/esp off light are on
Post by: Dazzler on February 13, 2018, 18:52:00
Hi coolbzk,
The worn bush is a separate cheap fix. There is plenty of info on her if that is required. I would probably not do it myself, but it depends on your levels of mechanical skills.
With the warning lights, you may get away with a reset in the short term at least, by disconnecting the negative terminal of your battery for a minimum of half an hour.
You may need to then do a short drive turning the steering fully to the right and left to calibrate it and clear the EPS light.
If this doesn't help and your power steering malfunctions (loses assistance or starts randomly pulling in different directions) then it may need replacement.
For the small amount of people who have had this issue not covered by warranty, the cheapest option is to try and source  a second hand one with some warranty from a wreckers yard or other part supplier. I think the last I heard the going price for that assembly secondhand was between A$500 and A$1000.
Hope that helps.
Post by: coolbzk on February 13, 2018, 20:38:34
much appreciated  Dazzler
i did disconnect negative pin on my battery, but just for only few minutes , the lights were still on after put the power back, till now. i think i will do it again following your advice to make it few hours for safe.
yesterday i also connected a BDO2 scanner trying to find something, and it actually gave me no error code at all.
booked hyundai dealer to diagnose my car next Monday and see what they can find.
i will keep update here.
again thanks for your inputs Dazzler~~~
Post by: Dazzler on February 13, 2018, 21:28:03
No problems.  If you need help finding any applicable threads let me know. Too much on this site now. Sometimes hard to find stuff!
Post by: panthersteve on February 15, 2018, 19:08:36
I have the same problem.
I replaced the bush myself following the instruction sheet that is somewhere on this site, it was not too hard to do.
However my lights are still on, connecting it to a scanner showed that it is the steering angle sensor having no output/not registering movement. Apparently the only way to replace this is to replace the whole power steering unit. Mine still drives ok with functioning power steering so have not bothered going any further with it yet.
Cheers
Steve
Post by: nzenigma on February 15, 2018, 22:16:46
ibooked hyundai dealer to diagnose my car next Monday and see what they can find.
@coolbzk   NO NO  NO! Sure we have supplied enough info to do the job yourself if you are handy.
But also supplied herein: clearly it is not a $ 4000 repair and clearly the dealer is on trend to empty your wallet.
If you were to do the 2.5hr repair yourself you would need to get your independent mechanic to set the ESP centre. 5 minute job with scan tool.
Post by: coolbzk on February 15, 2018, 22:22:23
Thanks Steve for your update
so you still have the eps /esp off lights on ?
Post by: coolbzk on February 15, 2018, 22:25:36
Thanks nzenigma, i tried to disconnect the battery for few hours , but the lights are still there.
not sure how to clear it , i may need to talk to my mechnican to check the error code, as my simple one didnt provide me any error code.
Post by: nzenigma on February 16, 2018, 04:07:12
No use trying to clear codes until bush is replaced. Fix that and ESP can be centred with Proscan or similar device. I dont think your mechanic has much knowledge about this bush replacement so ask some questions elsewhere, NOT the dealership. The bush is a fault common to many Hyundais so someone in your region has to be on top of it. Remember, it is only a 4 hour repair first time you do it.... therefore, your dealer was going to charge you $1000 per hour.
Post by: panthersteve on February 16, 2018, 04:56:24
Hi
Firstly to coolbzk, yes the lights are still on
Secondly to nzenigma, I think the $4000 quote was most likely for complete power steering unit replacement or maybe even just supply and not for just the bush. Also my lights could not be reset after bush replacement, there were no error codes and as the steering angle sensor was not outputting/registering movement the zero setting could not be done. If these lights are on for the same reason perhaps they also will not be able to be reset.
I have not read anywhere else where people having to do the bush have had these 2 lights on so think this instance may be the same as mine.
Post by: nzenigma on February 16, 2018, 16:36:24
Keep reading,
 @tw2005  and I have discussed this here at length. We have both contributed accurate information available if you use the search engine . The instruction sheet you followed is probably our work.
In several posts, I have mentioned that one or both lights will be on until steering is centred, also said EPS may stay on after engine is stopped. Battery must be disconnected and connected again.
PS this info comes from practical experience and many repairs.
Post by: nzenigma on February 16, 2018, 16:47:33
No codes will be showing. A cheap $30 scanner, that I assume you have, is very handy, but for the reset you need a more sophisticated workshop unit. Think $2500. :Pout:
Post by: panthersteve on February 16, 2018, 17:37:47
I don't have a scanner at all, what was used was an auto electricians unit, as you described, a sophisticated unit. While viewing the scanner the steering wheel was turned at which time there was no change to the steering angle, unlike other readings such as yaw that were changing as the wheel was turned to and fro
Post by: panthersteve on February 16, 2018, 17:42:19
Keep reading,
I probably didn't explain myself properly here, what I meant is I can't recall these 2 lights being on before the job of replacing the bush except in mine and this case.
As for the search engine I have used it extensively but never seem to be able to find what I am after and always seem to get results that are nothing to do with what I am looking for so tend to rely on those of you that know what you are talking about to provide advice.
Post by: Dazzler on February 16, 2018, 17:53:06
There is definitely a knack to using the search engine. I select Advanced search then untick all topics and selectively tick the most likely areas. Then search for most likely fault descriptions. It still usually involves some scrolling through topics to find the applicable ones. Not always a fun experience.  :crazy1:
Post by: tw2005 on February 16, 2018, 20:22:46
Keep reading,
I'm a little confused, so are you saying that you had a pre-existing fault with the angle sensor prior to replacing the coupling?
Post by: panthersteve on February 17, 2018, 05:20:02
Keep reading,
That is a definite yes from me and from the way I understand coolbzk posts it is also a yes for him
Post by: nzenigma on February 17, 2018, 15:47:12
Thats Not what he said    :crazy1:
Hi all,
then since last Saturday , both eps and esp off lights are on on my dash, the eps still works as the wheel is not that heavy, .....
Post by: panthersteve on February 18, 2018, 05:35:03
Hi all,
I think you will find that is what he said, further down the post you quoted he said,
Much appreciated!
So he clearly has not yet done the replacement nor has he had it done for him, therefore the issue of his eps/esp off lights being on before having replaced the rubber bush is the same as I experienced
Post by: nzenigma on February 18, 2018, 15:43:44
Whatever :wacko:
He's so confused now he is going to the dealer; I think today and ... :twisted: :twisted: :twisted:
Post by: coolbzk on February 18, 2018, 18:47:35
Hi all,
Much appreciated!
you are right, i have not done anything, and both lights are on.
with the scanner , no error codes
i think we are on the same boat.
i dont mind  the lights during daily driving, but can not sell the car with them.
Post by: coolbzk on February 18, 2018, 18:49:28
Whatever :wacko:
dealer rescheduled check to tomorrow
so i will make the update after tomorrow
the 4k quote is from dealer if they need to replace the fault column with a brand new steering column+labour.
my mechnican also said the best shot may find a second hand steering column to replace.
Post by: nzenigma on February 18, 2018, 20:32:24
Whatever :wacko:
Ok this thread has become messy because two separate members repairs are being discussed.
Tread carefully tomorrow   :cool:
Yes if you look at a replacement column., there are plenty of second hand ones about. Probably about $400. But here's the rub: the bush may be old , new, or never going to fail in the second hand column  :(
If I was going in that direction, I would still replace the bush. It will only cost you $5 - $20.
The time to open the column and replace it is only about  10 minutes.
To remove and reinstall a column is between 2.5hrs and 4 hours depending upon the mechanic's experience (incuding bush replacement).
Your mechanic is not familiar with this so he will charge  his hourly rate x 4. = $480
On balance, your column is as good as a 2nd hand one.
Q. What do you prefer , total of $485 or $880?
Post by: coolbzk on February 18, 2018, 20:53:39
Whatever :wacko:
yes, i will definitely replace the bush if i go with the second hand column.
for $485 or $880, depends on tomorrow's diagnose, if dealer can clear the error code (if there is any with their scanner) and switch off the lights, i will just replace the bush, if they can not and saying it is the column problem, i will go with $880.
Post by: nzenigma on February 19, 2018, 16:44:53
Bear in mind the light(s) will come back on when you install your column, be it your original or another, because it will be indicating a new centre position. Will need another reset.
Simple and only way to avoid this is to mark your original column before it is removed so that it is refitted into exactly the same spline on the steering rack. Also, the power steer motor cannot be rotated at all when fitting the bush.
Post by: coolbzk on February 20, 2018, 00:38:34
Here is the update from dealer
Dealer did the diagnose today and called me back , saying the lights are caused by the bush , and they need to take the whole column out and replace the bush, which will cost AU$440, i confirmed they will fix the lights after replacing the bush, this price also includes the diagnose fee, which is $121 if i choose somewhere else to fix it, so i let them go ahead.
Can not get my car back today, will see how it goes tomorrow
thanks all~
Post by: nzenigma on February 20, 2018, 03:54:59
 :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
Fair enough , I think they have been reading our mail.  :whistler:
thanks all~
much  appreciated  :goodjob2:
Post by: coolbzk on February 22, 2018, 06:42:17
Hi guys,
got my car back today, all good now, lights are off and no knocking/clunk anymore .
total cost is $445 from hyundai dealer.
they also show me the bush they took out from your motor, totally grinded just like others showed on youtube.
dealer charged me $50 for the new bush :Shocked:
dont know how they fix the eps/esp off lights
from the report there is an item called clear the error code , not sure if they have a special tool to  read it and clear
as my $7 scanner can not read anything.
anyway, happy have my problem fixed with this price.
thanks everyone.
Post by: Dazzler on February 22, 2018, 14:25:55
Good to hear, although they did very well out of the job...  :disapp:
Post by: nzenigma on February 22, 2018, 17:22:43
Thanks for the update coolbzk, appreciated by all of us.  :goodjob2: good to hear it has been resolved.
Dazz  re Bush price increase:
Ok it was only $5, but there is inflation, freight charge between two rooms in same building, admin fee, perusal fee, computer time....the costs are endless. $50 was a bargain! :faint:
Post by: Dazzler on February 22, 2018, 17:38:46
Yeah sounds like a certain rental company i used a while back (Hertz)
Only $10 a day extra for a much better car sir.. + GST + extra Admin surcharge + extra location Surcharge + Credit card surcharge.. Me no use them any more!  :fum:
Post by: nzenigma on February 22, 2018, 22:09:52
Some companies manage to do so much damage to their reputation for such paltry financial benefit.
