The i30 Owners Club
MODIFYING OR DETAILING YOUR I30 => ENGINE BAY => Topic started by: Bazza2401 on September 05, 2019, 00:37:25
Title: Turbo for i30 se 2013?
Post by: Bazza2401 on September 05, 2019, 00:37:25
Does anyone know if you can install a turbo in a i30 se 2013 2 door automatic?
Any information would be great thanks! And if possible how much itíll be!
Title: Re: Turbo for i30 se 2013?
Post by: CraigB on September 05, 2019, 01:14:58
Buy the time youíve bought the turbo and the rest of the associated parts required plus fitting-tuning-labour it actually works out cheaper to buy a wrecked Veloster or PD i30 and swap the engine - gearbox - driveline and brakes.
ECU modifications would still be required, even better if youíre able to purchase an ecu from one of the UK 2 door turbos.
You would have to ring around for costs, not cheap :)
Post by: mickd on September 05, 2019, 03:11:35
So much work , time , money,  engineers reports and effort for a sleeper .
Probably quicker, cheaper and headache free to buy a Veloster or PD.
But, if you still feel the need for   :Shocked:  :cool:   :evil: how about a nice bottle of nitrous,  easy to remove if defected too.
Post by: CraigB on September 05, 2019, 05:32:43
When I first bought my car I put a request into Sprintex Superchargers for a bolt on kit similar to what they designed for the Honda Jazz  :link: HONDA FIT/JAZZ (http://www.sprintex.com.au/honda-fit-jazz/)
Not enough vehicles around like mine to have made it a worthwhile build for them unfortunately :Pout:
Post by: Dazzler on September 05, 2019, 06:59:25
@CraigB are all your performance mods on your 2 door in one thread you can share with Bazza?
Post by: CraigB on September 05, 2019, 07:19:09
They're all over the place :whistler: can start with extractors  :link: 2012-2018 Veloster 4-1 Header - Shark Racing (https://sharkracing.com/2012-2016-veloster-4-1-header/) with custom exhaust, upgrade the catalytic to a gen 4 or higher to prevent post o2 sensor faults.
Big bore throttle body  :link: 2012-2018 Veloster 1.6 Big Bore Throttle Body - Shark Racing (https://sharkracing.com/2012-2016-veloster-1-6-big-bore-throttle-body/) I purchased a throttle body off a 1.8ltr from wreckers and tapped in the breather and removed the water lines, fits perfectly and gives 60mm bore to match intake manifold.
Open up the Airbox as mentioned in this topic  :link: Air intake revisited (https://www.i30ownersclub.com/forum/index.php?topic=47067.msg445574#msg445574)
When finished with all that you can then get someone to play with the ECU, limited to timing advances and air/fuel ratio changes but can add another 10kw on top of the other mods
Post by: nzenigma on September 06, 2019, 18:10:25
Craig's  thoughts about using a wreck motor is more practical.
To just boost a 2013 motor is  :Dunno: , hooked up to an auto :Dunno: running standard suspension? :Dunno:
I would rather rebuild the wrecked Turbo Veloster
