MODIFYING OR DETAILING YOUR I30 => ELECTRICAL | ELECTRONIC | AUDIO => Topic started by: stevenick100 on April 27, 2020, 09:39:48
I want to upgrade my car radio to something modern, my car is 2008. I'm not sure where to start? Is it easy to DIY or get one shop fitted? I would appreiate any suggestions or some advice from someone who has upgraded theirs.
Steve
:link: HOW TO: FD Body - Remove/Replace/Swap OEM (2DIN) headunit (https://www.i30ownersclub.com/forum/index.php?topic=36289.0)
Looks like a lot of fun. If you are just after bluetooth head unit they are plug and play (if you can find one).
So is this (plug and play):
you can order an android headunit. im also ordering one for mine
(https://i.ibb.co/3FXV80Z/1589118654059.png) (https://ibb.co/R6ntMCw)
I have upgraded my FD wagon with
Sb Acoutsics SB29RDNC-C0004 tweeters x 2
Sb Acoustics SB17MFC35-4 Midwoofers x 2
Alpine UTE-93DAB head unit single din (plays Flac Files)
JL Audio TWK audio processor
Alpine PDX-F6 150w x 4 amp
Alpine PDX-M12 1200w Subwoofer amp
Subwoofer 2 x Dayton audio RSS265HO-4 10" + 2 x Passive Dayton Audio RSS265-PR 10" in 45 litre box.
I have the same bracket as above except it's for a single din unit (didn't want something flashy)
Wasn't very hard to do , if you search on this forum you will find all information needed to remove the factory head unit and wiring.
Best sound system i have listened to in a car.
Well done! I'd love to upgrade the fairly ordinary stereo in my 2019 Camry but suspect I would be too tight to spend the required $ to get the result I'd want. I just want a bit more clarity, bass and volume, although my new hearing aids have helped a bit!
How much did you upgrade cost Mr X ?
About $3000
Although i didn't purchase everything at once , it took a couple of months so wasn't too bad.
I'm bit if an audio nut , so the cost is no problem for me.
Wow! That's probably more than a third of the value of your car. No wonder it sounds good. No criticizing you, it's your money. I'm a tight ass. I wouldn't want to spend more than $1000 to upgrade my Camry Audio and my car is still probably worth $30K. :-[ so probably wouldn't make enough difference to be worthwhile.
