Air conditioning. Hot air side driver and cold air side copilot.
Offline Frigorifico
    • es Spain
  • 2010 FD 5 Door, Diesel 1.6 128hp, Manual, White
Hello everyone,
The doubt is simple. I noticed that there is cold air coming from the grilles on the right side, while the ones on the left side are hot and very hot.
It emits hot air through all the grates except the right side:
Moon grid right part: Cold
Right front grille: Tempered
Grid right (next to window): Cold
Right front grille feet: Cold
Rear right side grille: Cold
I go with a heat that I die and my companion frozen ... Any ideas?
I have disassembled the car, I have checked that the Temperature Actuator works correctly, ie it is moving correctly. (REF: 971592L000)
Actuator:
Photos of the actuator.
It is really difficult to reassemble the motor because there is hardly any gap.
I have checked all kinds of connections and everything works correctly. The only thing that does not fit is a cable through the area behind the radio ... which is not plugged in.
( :link: What is this connector for? )
I have checked fuses, relays, etc ... and I can not find anything wrong.
I have taken the car to an official Hyundai dealership and they thought the same thing as me but on hearing what I have done, they have checked it and they do not know what it can be. They have to dismantle the whole dashboard ... until they see where the fault is ... and the arrangement can be very very expensive.
Can anyone tell me what it can be? Maybe the engine is failing even though it really opens and closes?
 need help, I'm desperate
Thank you!!!!!
  • i30 2010 - 128hp
Online The Gonz
As illogical as it sounds, this video explains it as needing a regas! :crazy1:
Online The Gonz
This one alerts you to checking BOTH servo motors' operation:
:link: How to Diagnose the AC Vent Problem: Hot on One Side, Cold on the Other - YouTube
Offline Frigorifico
    • es Spain
As I understand it, in this case the problem is that it does not cool ... not that it does not heat. The problem is in the cold, I have it in the hot.
  • i30 2010 - 128hp
Offline Frigorifico
    • es Spain
Yes, this is possible, it is possible that the car has a servomotor there. I have to dismantle that area.
One more thing, the air conditioner has a self-diagnosis ... that follows the following diagram. I can not get it to work. Could someone help me?
  • i30 2010 - 128hp
Offline Frigorifico
    • es Spain
I need help  :mad:
I'll tag our "master" technician @cruiserfied , but don't get "mad" I'm sure if anyone that has seen this could have helped so far they would have. :undecided:
Offline sesel
    • Middlesbrough
Similar issues here mine blows out cold air only and always water runs dry I have no antifreeze and using tap water as just bought the car, Seat heating OK but there is very little warm air u can feel in ventilation, I guess I need to check for leaks as I filled tap water fuel at night drove only 5 miles morning no water and I could see water on floor
  • Hyundai i30
Welcome sesel. Sounds like your i30 is past its prime! What with this issue and the steering bush. How old and what mileage? i30s are generally pretty reliable.
Online The Gonz
Frigorífico has posted his solution on the Spanish forum:
I went to the Hyundai dealer's workshop and they told me radiator was blocked. The hoses in and out were at 65 and 55 degrees, indicating the blockage since they should be the same.
Hyundai quote:
- 200€ radiador / heater core (50-60€ on Amazon, ebay)
- 200€ labour
- 50€ antifreeze
450€
I went to a local and for the investigation, flushing of the original core and some helpful repairs of joints and connections, total cost was 20€ (for the half hour).
So from Frigorífico's experience, flush your core. :goodjob:
The Gonz, our roving reporter, reporting live from our Spanish affiliate. ..
Online The Gonz
 :lol: :goodjob:
Onsite, no less! :crazy1:
Dealer is a prat, Why do we have a radiator? Answer; to reduce the temperature of the coolant.  :crazy1:
Unfortunately, members are still taking nonsense in this thread as sound advice, therefore my late edit.
