The instantaneous economy readout has me driving like such a nana.
Quote from: alexeiw123 on January 07, 2013, 02:53:16The instantaneous economy readout has me driving like such a nana.At your age too. That's good info
Quote from: rustynutz on January 02, 2013, 01:00:33I wonder if anyone else's GD speedo is out that much? My speedo is out around 2kph, but that is in an FD....Mine is, when the speedo says 90, the GPS says 84.
Quote from: Phil aka 84 on January 07, 2013, 03:09:06Quote from: alexeiw123 on January 07, 2013, 02:53:16The instantaneous economy readout has me driving like such a nana.At your age too. That's good info don't laugh, you should have seen my mates faces when I said I was getting a diesel hatchback! Kind of strays from the previous selection of cars.No regrets yet
Quote from: Lakes on January 07, 2013, 09:31:47The instantaneous economy readout has me driving like such a nana.That's great!, has the new GD Crdi trip PC got instant fuel useage readout?
Ok a couple more tests I have done. Same piece of road same tank of fuel 100km of highway reset average l/100km and cruise control at same point. 100km/hr 6th gear 1900rpm 4.1L/100km, 100km/hr 5th gear 2300rpm 3.9L/100km and 110km/hr 6th gear 2100rpm 3.8L/100km. Very interesting figures so it seems 2100rpm is the sweet spot and I think the extra 10km/hr must help when coming to a hill.
Quote from: THE i30 on January 07, 2013, 00:55:58Ok a couple more tests I have done. Same piece of road same tank of fuel 100km of highway reset average l/100km and cruise control at same point. 100km/hr 6th gear 1900rpm 4.1L/100km, 100km/hr 5th gear 2300rpm 3.9L/100km and 110km/hr 6th gear 2100rpm 3.8L/100km. Very interesting figures so it seems 2100rpm is the sweet spot and I think the extra 10km/hr must help when coming to a hill.Confirms my suspicions that 1500-1700rpm is probably below the sweet spot for the engine. Perhaps turbo not on boost and assisting. That's why even at 100km in the GD, the optimal fuel economy is 5th gear, not 6th.Things are a bit lower geared in the FD, so I think 1900rpm or so is the sweet spot which corresponds to about 90km/hr in 6th.
the confusing part is that on the dash screen, there is an indicator that tells you which gear to be in for best economy, and it will start recommending 6th gear at anything above about 65km/h which I feel is true for coasting along, but I always shift down before starting to climb at those speeds, even though the torque can easily pull you up a slight incline in 6th at those speeds.
Yes, but in the form of a pretty useless strip readout that tells you very little.
I turned mine off its so annoying flashing at you all the time
