EPS FAULT?
Aye30 · 11 · 3388
Offline Aye30
Our ESP Off light came on, on my wife's car, only when I drove it. Usually as I drove around a long sweeping left hand bend. It only happened before the brake light switch was replaced. And never after the recall fix. ( I use the brakes less around corners ). Is there a way to know if the brake light switch has been replaced in the recall?
I'm confused. :confused:
Esp when people keep using intls.
Offline ibrokeit
  • Author of War & Peace
Esp when they use the wrong TLA (easy enough to do in this instance) in the subject versus the content :D
Offline ibrokeit
Short answer: I would think you should be able to ring up a Hyundai Service Center, or contact iCare, and ask if the brake switch recall was done to it - I would assume it would be recorded against VIN on Hy Australia's system.
Longer answer: My smart reply (previous message mentioning TLAs) I just made not withstanding.  Your subject mentions EPS (steering) which is the subject of govt. website published recall for a specific range of VINs; while your content mentions ESP Off, ESP being the stability system (which relies on steering and braking, etc. for operation), and also the brake light switch - which wasn't a govt. published recall but was a recall by Hyundai.
You say it never happened after the recall fix, then ask if there is a way to know if the brake light switch was replaced - this has me confused as to which recall is being referred to?
The brake light switch recall, per what I was told recently at the service center, was to replace the original with a modified version (no idea if P/N is the same or modified) - so if you had the brake switch recall done then it would have been replaced (unless someone really mucked up).  Prior to the brake switch recall they had been replacing faulty switches, but of course the replacements had the same design issue (meaning some cars had it replaced a few times prior to recall).
The Steering (EPS) recall AFAIK is only about the steering and can/does involve a ECU update.   I would think the only reason the brake switch would be replaced then would be if the vehicle was recorded as never having had the brake switch recall applied.
Was the road slippy so braking action coming into its own to stabalise the car
The light indicated that ESP was off, not on.  :razz:
Offline ibrokeit
ESP confusion (and EPS confusion) at it's best :-)
The 'ESP OFF' light turns on to indicate ESP is disabled (fault or user input i.e. on/off button).
The 'ESP' light turns on to indicate ESP is actively stabilising the car.
So the off light coming on on a long left bend is probably an indication something is off with the system.  :D
That's what I said  :exclaim:
ESP OFF, so no braking performed by the vehicle on any bends.
Offline ibrokeit
It wasn't aimed at you!
O I C
Offline cruiserfied
  • Crooked-H Hero
If you can get a picture of the brake light switch I can tell you if its the new part. But if you've had the campain completed it should have the new switch.
Best I can recommend is getting a diagnostic check done.
