Author Topic: HOW TO: UPGRADE YOUR GD-01/GD-02 TO A GD-03 HEAD UNIT STEP-BY-STEP GUIDE  (Read 48577 times)
    NSW
Head unit is the latest software.
I canít find anything under ĎCarPlayí in settings. The vehicle doesnít come up 😩
And Siri is definitely enabled. If I clock on the Ďvoiceí button on the head unit it will activate Siri and lets me request things and answers all through the car.
But Iím still unable to select Ďapple CarPlayí on the head unit. Iíll attach a photo. The option is there but itís not lit up.
  • 2014 Hyundai i30
You should see in the phone carplay setting whats pictured below
If you're not seeing these options and with the other issues described of still charging but no carplay sync then I can only assume there is possibly a fault with either the lightning USB cable or possibly the interconnecting cable between the USB module and head unit., was the genuine interconnecting cable from the donor vehicle used?
You could also try running the firmware file again followed by initialising the system, sometimes the update needs two goes at it.
    NSW
Definitely not seeing that as an option on my phone 😩
And no itís Not the original cable from the donor vehicle. The guys at the wreckers used a pair of side cutters to take the head unit & AUX/USB jack assembly out. So the chord was cut in 2. I got one end but they said they couldnít get the other 😩 so I made a chord using an old computer fan cable. The pin sequence is all correct and I know Iíve got all the wiring correct. Yet still no luck.
Might cut my loss and just use the head unit for Bluetooth audio & radio! At least I can still charge my phone on the USB.
« Last Edit: November 20, 2019, 14:42:53 by kirstenp » »
  • 2014 Hyundai i30
And no itís Not the original cable from the donor vehicle. The guys at the wreckers used a pair of side cutters to take the head unit & USB jack assembly out. I made a chord using an old computer fan. The pin sequence is all correct and I know Iíve got all the wiring correct. Yet still no luck.
Reported symptoms all pointed to a lead/cable fault, you can purchase the lead via Hyundai or Koraps or via a link posted previously in this topic that aanastasiou4 placed  https://www.fourgreen.com/store/mobile/prodView.asp?idProduct=6145963#mobileMain
Well worth getting the correct cable for such a handy feature, don't think I could go back to a car without AA/CP now that I'm used to it :)
  • cy Cyprus
Go on your iPhone. Settings > Screen time > Content & Privacy Restrictions (if off turn it on) > Allowed apps. Make sure that carplay is on from there.
  • Hyundai i30 2012
Screen time should be disabled by default unless manually switched on.
  • cy Cyprus
« Reply #336 : November 20, 2019, 07:47:51 »
Apple carplay should be turned ON from restrictions so idk maybe he somehow turned it off that's why I had to mention the above process. It's very weird for the headunit not to recognise  apple carplay when the phone is plugged in!
  • Hyundai i30 2012
Apple carplay should be turned ON from restrictions so idk maybe he somehow turned it off because it's very weird for the headunit not to recognise  apple carplay when the phone is plugged in!
Did you miss the part where the interconnecting cable used was home made :whistler: :D
And I meant the complete Screen time function should be default disabled at the home screen which would in turn mean that any options there after should not be available, which is how I have mine set.
  • cy Cyprus
Yes I did miss the part which says that the cable was homemade! Now that is the reason hahahah
  • Hyundai i30 2012
    Stoke on Trent United kingdom
Try some of the steps on this page if CarPlay isnít showing in iPhone settings>general
 :link:CarPlay trouble shooting
If you get no luck then you may need to buy a genuine usb cable for the head unit. Have you tried a usb stick with music or another phone?
« Last Edit: November 20, 2019, 18:21:35 by StokeyBry » »
So I have a late 2012 GD i30 Premium model, with the sat nav head unit. I just bought the NON sat nav GD-03 and was delivered today. I hit ďbuyĒ just before I realised this might be quite a big job, as I think this requires quite a lot of rewiring etc. Not to mention a new fascia.
Two questions. First, am I right in thinking this is quite a big job?
Second, Iíd say this is too hard for me to do myself, and what car audio installation places do you trust and recommend to get this job done?
Thanks!
  • 2013 Hyundai i30 Premium GD
Not a big job at all itís all plug and play, but you may have to use the facia from your current head unit for the gd-03
You can't swap the head unit fascia from a NAV to GD-03 as the buttons are different, you would need to swap the climate control fascia from current Premium to Active (base model).
Everything else should be plug and play I think :undecided:
Great - I've been looking at getting a standard fascia, but it doesn't seem like anyone is selling them without the actual controls. Thinking I could get it for much cheaper if I could find that. Any ideas here?
Any ideas here?
No wrecker will separate the aircon fascia, they would be left with a aircon module that they couldn't sell.
  • cy Cyprus
If you get the whole unit, the glossy black trim can be pulled off and installed on your current climate unit.
  • Hyundai i30 2012
Any ideas here?
Thanks Craig - I figured that might be the case. Wasnít sure if 3rd parties might sell this part aftermarket or something. Will have to get the full unit in that case.
  • cy Cyprus
Any ideas here?
Yes! Get the cheapest one you can find but make sure that the glossy part is not full of scratches
  • Hyundai i30 2012
And no itís Not the original cable from the donor vehicle. The guys at the wreckers used a pair of side cutters to take the head unit & AUX/USB jack assembly out. So the chord was cut in 2. I got one end but they said they couldnít get the other so I made a chord using an old computer fan cable. The pin sequence is all correct and I know Iíve got all the wiring correct. Yet still no luck.
Contact this seller  (ultimatejap)on eBay and ask him for the OEM cable.
  • Warsaw, PL
I would be very surprised if it's the cable. There's nothing special about it, I measured it when I repaired mine and it's simply 4 x 2 feet of copper.
Did you follow the full instructions while upgrading? There are several parts to it, and afterwards you are supposed to do a full settings reset. Did you do all of these?
  • i30cw 2013 1.6 auto
You can get away with repaired cables on Android Auto but Apple CarPlay is extremely fussy when it comes to cables.
If the chip doesnít receive the correct voltage or sync data then the phone will charge but will be unable to recognise CarPlay.
« Last Edit: December 05, 2019, 15:33:35 by CraigB » »
You fix the unit?
  • Warsaw, PL
I soldered together the two ends of the cable. It was cut by ultimatejap's dismantlers.
4 wires and a shield. Nothing to it. We're not talking about GHz signals through these cables. If we were, I'd have used the spectrum analyzer to to a DTF analysis.
It took me 10 minutes, 7 of which was making spent on a cup of coffee.
Now all good?
anything
