Author Topic: oil change  (Read 1346 times)
  • il Israel
    Israel
oil change
« August 04, 2017, 15:29:33 »
as I reached the 15000 km mark, I thought I will do the service myself.
bought oil, genuine oil filter and air filter.
first thing that was weird, the oil filter did not have the Mobis sticker (could be some second source oem) and the pn was 1 number up, the one that was fitted with the Mobis sticker ended with 03 and the one I bought ended with 04. both were the same otherwise.
the oil filter did not come with the crash washer, so I bought a copper crash washer.
started with building a ramp to lift up the car.
all the info I about oil change is for the 2L petrol engine or Diesel  engine.
as it appears, the drain bolt in the 1.6L petrol is facing to the front of the car and not to the back.
the oil filter is in the middle and not blocked by any cover, and facing down.
opened the drain plug and discovered that the mechanic did not use a crash washer, just tightened the bolt so much that it nearly destroyed the thread.
go and relay on professionals.
taking the oil filter off took me about 1.5 hours. after a long battle and bloodshed, I discovered that my chain oil filter wrench, was just jammed against the engine block. this is why the filter would not move  :Jaw:
after realizing this, kept the chain on the edge of the filter and half a minute later, the filter was out. time to get a decent wrench.
my daughter changed the air filter by herself (almost).
after a Friday full of making, the wife is upset that I did not have time to help her with the cleanings.... :Hos:
ramp
ramp
car on ramp
air filter
storage
« Last Edit: August 05, 2017, 02:45:42 by yodm » »
  • I30 CW 2010 1.6 petrol auto
Re: oil change
« Reply #1 : August 04, 2017, 16:09:58 »
Thanks for sharing. For some reason your images are not showing on tapatalk?
  • Author
  • il Israel
    Israel
Re: oil change
« Reply #2 : August 04, 2017, 16:39:04 »
it takes time for the pictures to load and show.
from past experience it takes about 2 hours from inserting the pics until they show up.
Re: oil change
« Reply #3 : August 04, 2017, 17:59:11 »
No problems.
Re: oil change
« Reply #4 : August 04, 2017, 18:15:59 »
They're links to html pages, not image files, so they'll never show up.
Re: oil change
« Reply #5 : August 04, 2017, 19:01:34 »
At least  you did not drive the car straight off the car ramps with a bang :whistler:
Re: oil change
« Reply #6 : August 04, 2017, 19:26:06 »
That's never happened to me before. ( no crush washer fitted) if that was how it was,  i would be very  :crazy1:!!
Hope you drove your car first to warm motor up before dropping oil. I don't chage my own now as you get stuck with the old oil.
I used to be able to take it to recycler but there wharehouse burnt down. I was asking people what they do with there old oil one lady in Sydney paints all the tele poles with her old oil  :fum: another guy said in Victoria they burry a drum of old oil  :fum: so i just go to NRMA workshop get mine serviced now.
Re: oil change
« Reply #7 : August 04, 2017, 19:57:10 »
Hi, supercheap usually have a bin to put old oil in for disposal.
  • 09/16 GD4 SII Active X 5dr 1.8 6sp A. 02/18 DM5 Santa Fe H/lander 2.2 6sp white
  • Author
  • il Israel
    Israel
Re: oil change
« Reply #8 : August 05, 2017, 01:55:56 »
changed the links to the pictures. should work now
Re: oil change
« Reply #9 : August 05, 2017, 17:56:18 »
Thanks, I like your simple but effective ramp design. Bought ramps can be expensive!
Re: oil change
« Reply #10 : August 05, 2017, 18:04:01 »
only the first time. After that they're free.
Re: oil change
« Reply #11 : August 05, 2017, 18:25:37 »
I remember the money I spend for a long time..... :D
Re: oil change
« Reply #12 : August 05, 2017, 19:26:58 »
Great idea !
I may have missed it , but, dimensions of wood you used to build them please.
  • Author
  • il Israel
    Israel
Re: oil change
« Reply #13 : August 06, 2017, 11:39:31 »
I don't have the wood dimensions and only in the weekend I will be able to measure.
but I have the dimensions I cut and used.
3 logs of 60 cm in length, 6 logs of 10 cm in length.
10 cm overlap between each step of 60 cm.
put another 2 pieces of 10 cm in the middle of the last section where the wheel stop for extra support.
 and a stopper just before the end of the last section. used my eyes, did not measure.
the firewall at work would not let me add an image so I attached one. hopefully it will load.
if not, on the weekend from home I will load it.
Re: oil change
« Reply #14 : August 07, 2017, 04:13:31 »
Thanks mate !👍
  • Author
  • il Israel
    Israel
Re: oil change
« Reply #15 : August 07, 2017, 09:51:23 »
this ramp gives enough clearance for me to go under the car and not feeling claustrophobic.
I am not so small, can loose 15 kilograms or more.
so if you are a big guy, you will need a forth section, but then the car would tilt too mach to the back.
Re: oil change
« Reply #16 : August 09, 2017, 05:19:40 »
Our local council dump takes up to 20 litres of scrap oil free of charge.  :goodjob:
  • 2013 Toyota Corolla Ascent Sport 6sp Manual. formerly 2009 i30 Hatch 5sp Manual.
  • Author
  • il Israel
    Israel
Re: oil change
« Reply #17 : August 10, 2017, 13:47:51 »
I used an old log that was laying around in the garden.
its 19 cm by 4.5 cm.
for each ramp I used 3 60 cm long sections with overlap of 10 cm.
Re: oil change
« Reply #18 : August 10, 2017, 18:58:58 »
Thanks yodm,
Some people wooden be that tight (see what I did there) but I probably wood... :cool:
  • Author
  • il Israel
    Israel
Re: oil change
« Reply #19 : August 11, 2017, 06:16:32 »
Dazzler,
I am not familiar with the Ausy slang so couldn't understand what you wrote.
the only words I know of in Ausy are cheers mate, and that's about all.
when I was young, we used to watch home and away......
Re: oil change
« Reply #20 : August 11, 2017, 06:19:34 »
Dazzler,
Sorry, it was a play on words.. wooden instead of wouldn't (being that you used wood to make the ramp)
  • Use it or lose it!
    • Professional Biography
Re: oil change
« Reply #21 : August 11, 2017, 06:19:50 »
Wood you watch it now? I wooden. :whistler: :lol:
