Author Topic: LED Number Plate and Interior Lights  (Read 5422 times)
Re: LED Number Plate and Interior Lights
« Reply #60 : November 03, 2018, 22:26:07 »
You wont be disappointed
Bought, now the wait :)  I've been following @CraigB recommendation from shampoo to drying towels, and now LED, been good so far - so I'll continue to stick to his recommendation  :victory: :goodjob2:
:happydance: :hatoff:
« Reply #61 : November 08, 2018, 01:45:14 »
@CraigB Reverse LED arrived and now installed !!! .. woohoo :) Now im going back into my hole again until someone else make another LED recommendation  :crazy1: :rofl:
« Reply #62 : November 08, 2018, 03:26:01 »
That was quick  :goodjob2: which ones did you get, the type Iím currently using or the new generation? I might order some of the new gen type to test and see how they compare :)
Have you done the indicators yet :mrgreen:
« Reply #63 : November 08, 2018, 04:13:33 »
Which ones did you get, the type Iím currently using or the new generation? I might order some of the new gen type to test and see how they compare
I got the new gen that you recommended - :link: 2PCS 12V 24V 60W LED CREE T15 W16W Car Reverse Turn Signal Backup Light bulb | eBay
I haven't test it out yet, will do in a few mins when I am taking the family out for ice cream.
Regarding to indicators - That seem to require more effort to remove and replace them, also the LED have to be yellow right?  Any recommendation? :P
Update:  Oh wow, reverse camera at night is no longer grainy.  I should have done this sooner.
« Last Edit: November 08, 2018, 05:14:34 by Blazorax » »
« Reply #64 : November 08, 2018, 05:27:17 »
Indicators are here :link: 1 x Canbus BRIGHT AMBER LED INDICATOR BULB No Hyperflash BAU15S PY21W ? Classic Car LEDs
Theyíre extremely bright though no resistors are required with these, crustycottage amd myself are running these and love em :)
I've noticed they now have an option for 750 lumen bulbs which are currently out of stock ( 10 days till re-stocked ), they might be a better option as the 1500 lumen bulbs are super bright.
« Last Edit: November 08, 2018, 13:54:42 by CraigB » »
« Reply #65 : November 08, 2018, 16:26:13 »
Too late bro, already paid  :)  Now the wait.
« Reply #66 : November 08, 2018, 23:35:54 »
Geez youíre quick :)
« Reply #67 : November 08, 2018, 23:53:18 »
Geez youíre quick
After all your good recommendations so far, i took your words as gospel.
« Reply #68 : November 09, 2018, 00:03:24 »
Geez youíre quick
Gospel from the good book says you will see the light :D
    NSW Australia
« Reply #69 : November 09, 2018, 02:08:40 »
I too got the LED backup lights recommended by CraigB. I had no trouble replacing them in the current model SR but with the daughters GD SR I can't get the old ones out. The holder goes loose when I turn it  but will not pull out from the light assembly. I did the same on the new car and it simply pulled out.  Is there something different in the 2 models?  By the way CraigB your recommendation for these lights was spot on. They are great!! :happydance: :happydance:
  • I30 SR GD4
« Reply #70 : November 09, 2018, 03:10:30 »
:hatoff:
Just have to wiggle them around a bit to get them out on the GD, if they're going to be really stubborn you might have to remove the light to do it.
    Australia, Perth
« Reply #71 : November 09, 2018, 06:15:37 »
As Craig stated they plug straight ini and are superbright. other road users will definitely see you indicating so no worries there.  :cool:
« Reply #72 : November 09, 2018, 16:23:40 »
After all these LED upgrade, I will no doubt have a flashy rear  :rofl:  comparable to Kim Kardashian
« Reply #73 : November 09, 2018, 20:52:18 »
Hopefully it looks more flashy than a Kardashian rear :sicky: those rears need their own reverse alarms :D
    NSW Australia
« Reply #74 : November 09, 2018, 21:19:19 »
Thanks CraigB, I just wasn't sure of how much I could pull on the globe holders. These do really make a difference especially on the reversing camera at night.  Would never thought of changing globes if I hadn't seen it on this forum. Great place for help. Cheers all :) :)
  • I30 SR GD4
« Reply #75 : November 09, 2018, 22:26:02 »
You're welcome :goodjob2:
Yes they make a huge difference, the comparable differences between the two bulb types are so dramatic that car companies should be fitting these for safety standards, plus it clears up the grainy rear camera issues :)
« Reply #76 : November 12, 2018, 06:55:47 »
Thought I'd upload a couple of photos to show the quality of the new generation LED reverse lights.
Not that the previous were poor at 500Lm but the new one's are a little brighter at 600Lm with fewer LED chips, they also make use of reflection technology which the last generation didn't have.
Nice and bright
Clarity of revision cam which also shows how the reverse lights illuminate the houses across the road.
Bought from reliable Aussie supplier :link: 2PCS 12V 24V 60W LED CREE T15 W16W Car Reverse Turn Signal Backup Light bulb | eBay
« Last Edit: November 12, 2018, 08:30:59 by CraigB » »
« Reply #77 : November 12, 2018, 10:40:11 »
Impressive.  Wish the PD camera was that clear at night. Even with the LED reverse light, still quite grainy.  :Pout:
« Reply #78 : November 12, 2018, 16:03:13 »
It seem quite clear when I used that on my PD2 - did you get the new LED CraigB suggested bro?
« Reply #79 : November 12, 2018, 16:41:18 »
Mine are the earlier ones I think. It helped a lot, but still quite grainy. Nothing like the picture Craig posted.  :cool:
    NSW Australia
« Reply #80 : November 12, 2018, 18:49:01 »
I put the globes CraigB  suggested into both my daughters GD and my PD and the camera in both is like his picture shows, not grainy. I live in a retirement village and the lights light up the house across the road. Really you cannot compare to old globes. These should be standard. Excuse the pun but the led globes are brilliant.
  • I30 SR GD4
« Reply #81 : November 17, 2018, 19:11:42 »
Installed - the indicator is so flashy now - pure sexiness
    Australia, Perth
« Reply #82 : November 17, 2018, 20:21:48 »
I wasn't kidding when I said they were bright. Hand out those welding masks.  :goodjob2:  :cool:
« Reply #83 : November 18, 2018, 05:27:34 »
it was bright this afternoon - yet just took the family to dinner just then - it is so bloody bright at night -  You are sure not lying regarding welding mask.
« Reply #84 : November 20, 2018, 10:43:15 »
The 750 lumen bulbs are back in stock if anyone is interested :link: 1 x Canbus BRIGHT AMBER LED INDICATOR BULB No Hyperflash BAU15S PY21W ? Classic Car LEDs
The standard halogen 21W indicator bulb ranges anywhere from 250 (coloured) to 360 lumens (clear), Classic Car Led has two brightness options with their LED bulbs ranging from 750 lumen to 1500 lumen.
The 1500 lumen bulbs are as bright as headlights so be warned of their brightness...the 750's might be the better choice.
« Last Edit: November 20, 2018, 11:09:03 by CraigB » »
    Adelaide, SA
« Reply #85 : November 29, 2018, 05:31:35 »
I am gonna do the lazy thing and ask which LEDs are suitable for the boot compartment.
I bought some but they were too big to fit
  • 2018 PD Active 5 Door Hatch, Petrol 2.0, Auto, Plat. Silver
« Reply #86 : November 29, 2018, 08:25:18 »
Should be 31mm like these if they're the festoon type :link: 4X 12V 31MM FESTOON 7020 4 LED CAR UTE 4WD INTERIOR DOME MAP LIGHT BULB GLOBE | eBay
    Adelaide, SA
« Reply #87 : November 30, 2018, 03:14:53 »
Ah, I got the 36mm. Thank you
« Reply #88 : November 30, 2018, 03:22:12 »
    NSW Australia
« Reply #89 : December 03, 2018, 02:26:29 »
I changed the  interior festoon globes to LED a little while ago. What I found was the metal section of the standard festoons globes fitted by Hyundai were a little shorter than a standard 31mm globe ( globe overall about 29mm) and also the 2 u shaped contacts holding the globes in where a little closer together. When fitting the new LED 31mm globes the heatsink on the back of the globes shorted on the U shaped retainers. Easily fixed with a little pressure on the retainers to spread them a little further apart. Problem solved.  Same with the light in the boot. Also it did not matter what polarity you put the LED's in, they worked in both directions. The new LEDs where the same ones in the link CraigB provided. Big difference in light output and no longer a yellowish colour , now a bright white.
  • I30 SR GD4
anything
