Author Topic: problem with tyre sensor valve shearing off  (Read 1443 times)
« February 28, 2018, 06:42:45 »
Beware anyone with a rigid allamium tyre valve with tyre monitoring system.
My car is brand new not even 4 weeks old hyundai ioniq hybred premium.
Went to blow tyre up a siansburies petrol station. Tyre valve sheared off resulting in instant flat tyre
Contacted  local hyundai dealer in Scarborough not coverd under warranty because I didn't put air line on straight.was told by service manager that hyundai are aware valves shear of.
I said was never warned about this problem.
Did some research online happened to few people with these valves. Also valve can corrode over time and snap.
Rang hyundai to complain was told only can be replaced under warranty if deemed faulty by dealership.said I wasn't warned about this and hyundai should come up with as these valve s over 100 pounds plus fitting.
The valves are to rigid not long enough .not enough clearance to use a standard airline at petrol station.
hyundai always harping on about how good there warranty is .Why not come up with fix. Hold hands say valves to brittle cover against accidental damage.
This is 20000 pound car shame about tyre valves.
When you research online hundreds complaints reguarding hyudia warranty.
Not good enough for 4 biggest car builder.
Anyone had this complain by letter to hyundai to get it altered.  :crazy1:
  • hyundia ioniq hybred premium
Re: problem with tyre sensor valve shearing off
« Reply #1 : February 28, 2018, 06:57:00 »
Yeah, one of those moments where you'd like to say I've been driving and inflating my own tyres for decades with no issue. Not suitable for the purpose.
Not knowing anything about these but if they are that delicate that they snap with routine service, how will they go with heat and age and what about debris when driven?
Sometimes the old keep it simple stupid applies.
« Reply #2 : February 28, 2018, 11:52:11 »
How do they know air line not on straight?
Unless you told them it must be their best guess then i presume it is a known issue.
So how and or what are you to use to inflate tyres if you can not use garage airlines?
« Reply #3 : February 28, 2018, 13:09:19 »
Sorry to hear that.  Thanks for the warning. I better be gentle.  Assume mine is the same on current model PD SR.
In Hyundai's defense I am guessing these valves are probably identical in quality and possibly from the same supplier as numerous other brands.  :cool:
  • KIA Niro 2 1.6 Petrol Hybrid
« Reply #4 : February 28, 2018, 15:52:16 »
I can recall several posts on this forum some time ago for the same problem with broken and corroded TMP stems . I have a Michelin tyre air compressor which plugs into the cigar lighter socket. The hose end is a brass straight screwed connector which is easy to fit and does not put any sideways load on the valve stem.
I never use garage pumps - the end fittings are too bulky and the accuracy of their pressure gauge is anyone's guess.  I was once filling my car and a guy opposite was blowing up his tyres. He walked round the car, tripped over the hose and broke the valve off. Hence I am very careful when checking/blowing up my tyres.
  • 2017 KIA Niro 2 1.6 petrol Hybrid
    Perth WA
« Reply #5 : February 28, 2018, 16:14:48 »
Just go to a different dealer...
  • 2017 i30 Elite PD
« Reply #6 : February 28, 2018, 16:41:54 »
Which doesn't in any way reduce their responsibility to utilise a quality product which is fit for purpose.
It's not rocket science. Remember the chrome, bolt on valves used in alloy wheels. You couldn't break them off with a hammer. And no corrosion issues even on beach vehicles.
« Reply #7 : February 28, 2018, 18:48:14 »
Stupid set up. Only way to check tyre pressure is to go to  a dealer,  their fault if it breaks  ?
  • 09/16 GD4 SII Active X 5dr 1.8 6sp A. 02/18 DM5 Santa Fe H/lander 2.2 6sp white
« Reply #8 : March 10, 2018, 10:38:41 »
Are these valve stems part of the TPMS and retained when tyres are changed and do they require special dust caps?
« Reply #9 : March 10, 2018, 12:09:54 »
Yes, yes and no. Yes to your first two questions, but no to your third from what I can see. the valve caps look normal tp me.
    Samford Valley
« Reply #10 : March 10, 2018, 16:11:49 »
That has to be the argument with Hyundai.
Furthermore, if they are that delicate they will probably snap off when you drive through snow, mud or deep puddles?
  :whistler: Be disastrous in Tazzie  :cool:
« Reply #11 : March 10, 2018, 22:53:09 »
:evil:
Your getting mixed up with NZ! Only driven on snow about 3 times in 40 years.Same for muddy roads..
...and generally our roads are pretty good.  :P
    Samford Valley
« Reply #12 : March 11, 2018, 01:00:10 »
40 years before climate change   :evil:
« Reply #13 : March 11, 2018, 06:14:23 »
Funny you should say that because our ckplimate has changed quite a bit down here in the last 5 years. Longer, warmer summers. Much bigger rain events.. etc.
    Samford Valley
« Reply #14 : March 11, 2018, 16:30:21 »
Similar up here, certainly hotter summer days. We have had weeks of rain, still on going, but I remember long wet seasons when I came here in the 1970s.
NZ is probably similar to Tazzie. BIGGER storms. drought in the usually wet windy Wellington, and then snow in the city.
« Reply #15 : March 12, 2018, 12:46:41 »
Thanks for answering my questions referring to dust caps and replacement of valves.
My new PD is my first car with TPMS.
Up to now whenever a tyre has been fitted (even after a puncture repair) the valve has been replaced.
I've also read of some dust caps causing problems by adhering to certain valve stems.
In some respects the TPMS is quite useful. When I drove my car away from the dealer the pressures were shown as being high (even for me) and unequal. In due course I adjusted them all down (much easier than inflating them) to 38 psi using my own pressure gauge. Remarkably the TPMS display matched  my gauge. Now I use the TPMS display instead of checking pressures manually. I'm happy enough all the time all four tyres are a similar pressure in the high 30s psi.
« Reply #16 : March 12, 2018, 15:57:25 »
I quite like the TPMS. Had 32+ cars and this is my first with TPMS. Not as common in Australia in affordable cars as in Europe.
I find it very accurate compared to a manual gauge too.   :goodjob:
I run 34 psi all around (cold) goes to around 36 after a bit of driving. I makes quite a reduction in tyre noise on our coarse bitumen roads compared to say 38 psi
    Coventry
« Reply #17 : May 13, 2018, 10:00:12 »
Hi, my TPMS  valve broke off in 2012 (2009 car),did a bit of googling, found it is a very common problem. Went back to dealership, salesman asked me how can i help,as they do. So  I explained, had only bought the car 2 weeks earlier at 3years old, first time i blew up tyres  problem with valve. did not even have to explain prob. i simply asked him you know what the problem with tpms valves are, and yes he replied correctly that they break off, so he knew as well that it is a KNOWN PROBLEM, which i later pointed out I had done my homework on internet and this site. Also gently pointed out that if a stone was to hit on motorway etc the rapid deflation would have caused what is in effect a blowout, so serious safety issue. A new valve was ordered and fitted free. I also pointed out on the 2nd visit that oneof the other valves was also corroded but not yet broken ,so another valve ordered and fitted free. tried to get a 3rd valve replaced as corrosion on that one as well, but not enough to warrant replacement by them.
  • Hyundai i30 1.6 CRDi (116bhp) Style
    Samford Valley
« Reply #18 : May 13, 2018, 16:42:28 »
  :goodjob2:
Amazing what you can find on the net: some news, fake news, porn and car advice. Makes my day! :victory:
« Reply #19 : May 14, 2018, 17:37:16 »
What about fake porn?  :Shocked:
« Reply #20 : May 14, 2018, 18:15:48 »
It's a good thread, but such a pity that mikeharry2006 hasn't visited since he/she created it :rolleyes:
  • 2008 FD i30 PremiuIoniq MY2018 SE Premium Hybrid in Polar White with added oomph
    Samford Valley
« Reply #21 : May 15, 2018, 00:00:02 »
Noooo! its true, all true. Promise me that!   :blubber:
« Reply #22 : May 15, 2018, 03:05:12 »
Bugger! I'll have to watch it even more closely now to try and spot the fake bits!  :crazy1:
    Samford Valley
« Reply #23 : May 16, 2018, 02:13:53 »
Ohhh Dazz, you shouldn't miss the  fake bits, they are " visually significant". Possibly a life changing experience.  :happydance:
« Reply #24 : May 16, 2018, 04:57:47 »
 :evil:
