Author Topic: 2010 i30 1.6crdi front left spring broken  (Read 3210 times)
  • cs Serbia
    Belgrade
« April 15, 2018, 03:33:38 »
Hello,
I have a problem,
The front left spring was broken on my car i30 1.6crdi 2010
I found another spring with another car (as in the picture below) but I do not know if it's for diesel or gasoline car!  They are not the same!
I ask for your advice and help  :question:
« Last Edit: April 15, 2018, 09:17:20 by Safari » »
  • Hyundai i30 1,6 crdi 2010
Re: 2010 i30 1.6crdi front left spring broken
« Reply #1 : April 15, 2018, 04:31:08 »
Intriguing problem.
Unless there's a part number on the spring I'm not sure how to answer that.
One of our tech people may have some suggestions.
  • 2013 Toyota Corolla Ascent Sport 6sp Manual. formerly 2009 i30 Hatch 5sp Manual.
« Reply #2 : April 15, 2018, 04:40:12 »
So how do we help you based on one photo? More information, year model spec of vehicle the spring came from would be of help.
usually there are colour codes on the springs to identify but I'm fairly certain the springs on the front of the diesel have a different rate compared to the petrol as the desel front will be heavier, then there could be a diffrence because between auto and manual,
I have 3 diesels, one manual and the front springs on the manual are different part number to my 2 autos
« Reply #3 : April 15, 2018, 04:41:14 »
Oh, my compliments of colour  choice 9A,
« Reply #4 : April 15, 2018, 06:12:01 »
« Reply #5 : April 15, 2018, 06:52:16 »
You could enter your VIN into ILCATS and find the spring fitted originally. There's a fair bit of variation so I have no way to be sure.
Europe  market I found 54630-2R130 for diesel manual both GL , GLS,
54630-2R140 for Auto
 if it had 17" wheels from factory
 54630-2R030 manual
54630-2R040 AUTO
Petrol
Having a look at 2.0L petrol if it's the same spec it's the same springs that is auto for auto , manual for manual and the 17" factory also match the diesel.
That or look for the paint markings if they're still there
« Reply #6 : April 15, 2018, 06:57:51 »
On my diesels the autos have
54630-2L040
manual has
54630-2L030
But different markets, different specs quite often
« Reply #7 : April 15, 2018, 07:11:48 »
Here's a link which is a good example of the markings. I see yellow, green, white
claims it's 546302L130
:link: AMORTIZER + VZMET SL 546302L130 :: bolha.com
« Reply #8 : April 15, 2018, 09:09:50 »
OK,
I will try to give more information.
I photographed part of the spring above the wheel.
I see that the spring is broken and these two colors: green and white
What does it mean, can it help?
The spring from the above image is from i30 2009, but it is not known whether it was removed from diesel or gasoline cars.
« Reply #9 : April 15, 2018, 10:50:11 »
How do I use this table?
I know colors on spring, but I do not know what that means in practice
My engine is D4FB xxxxxxxxxxxx
D 1.6 TCI-U2
« Reply #10 : April 15, 2018, 16:59:04 »
Yes I would like to know too how to read but I'm thinking this.
Ignore the top white mark, the lower markings I'd use So I have one here with just yellow, I put that link and I reckon that's green yellow.
Hard to tell without the spring removed and clean plus there may be some plastic wrap on the coil too.
    Samford Valley
« Reply #11 : April 15, 2018, 17:25:58 »
Mate well done so far  :whistler:
@Safari  Im not sure where you 'found' the spring and other car. But it seems more practical to go to a wrecker and buy a complete strut from a good CRDi.
Im assuming that yours broke because of ice conditions that we don't experience. How good is your existing shock absorber?
« Reply #12 : April 15, 2018, 17:43:27 »
Great minds think alike! I just told Gerard that in a PM.  :snigger:
You guys sometimes do miracles (or at least give them your best shot)  :victory:
    Samford Valley
« Reply #13 : April 15, 2018, 17:59:15 »
  :goodjob2:
Thanks Dazz, we rely upon your guiding wisdom as we shoot ourselves in the foot  ..umm, feet.  :mrgreen:
    Central Vic
« Reply #14 : May 24, 2018, 21:50:03 »
I gather this was resolved okay. In another life I used to design coil spring for manufacture and these coils pictured above seem not be tapered wire and the helix/spiral is uniform and seems the only determining factor about what ride height you get is the free length.  That is a pretty straight forward listing so I'm assuming the are using same wire size /no taper.
If that wasn't properly resolved I do have access to coil spring info on most stuff ...retired but not locked out yet. ;-)
  • i30 FB   Com VX & 73 Holden 3onthetree
« Reply #15 : May 24, 2018, 23:23:59 »
I'm not sure about the specs of the springs, but your offer is appreciated. Our tech heads will understand you better.  :victory:
anything
