Author Topic: Backup OEM camera retrofit  (Read 1078 times)
  • cy Cyprus
« April 24, 2018, 07:49:46 »
I retrofitted today the OEM hyundai badge camera. I only connected the open/close function since I am waiting for my GD-03 head-unit to arrive!
Sent from my iPhone using Tapatalk
  • Hyundai i30 2012
Re: Backup OEM camera retrofit
« Reply #1 : April 24, 2018, 07:52:53 »
So this will fit any GD model?
« Reply #2 : April 24, 2018, 15:27:37 »
Yes! You have to remove the badge of a non camera fitted model and cut the hole for the camera assembly! You have to splice the wires and extend them to go all the way to the radio (gd-02, gd-03 radios only)
Red wire: connected to the battery
Black wire: negative
Green wire: connected to the backup bulb
Blue wire: (ignition) connected to the + of the cigarette plug.
The above wires are only for the open/close function. When I connect the camera I will explain that too!
« Last Edit: April 24, 2018, 15:54:59 by aanastasiou4 » »
  • Hyundai i30 2012
« Reply #3 : April 24, 2018, 17:02:59 »
@aanastasiou4
 :ta:
What steps did you take to avoid future corrosion issues on the cut edge and what did you use to cut an oval hole. Was it tricky?
« Reply #4 : April 24, 2018, 23:33:33 »
I used touch up paint on the cut edges. To cut the hole I marked the area and used my drill to cut through!
  • Hyundai i30 2012
« Reply #5 : April 25, 2018, 05:21:16 »
Link to rear view camera thread
#11 This is what it looks like when installed  :goodjob:
  • 2016 GD, 5 door hatch 1.6 CRDI 110 BHP, manual, silvergrey
« Reply #6 : April 28, 2018, 02:03:18 »
I connected the camera too and it works perfectly!
  • Hyundai i30 2012
« Reply #7 : April 28, 2018, 04:32:32 »
Excellent! Well done!  :victory:
« Reply #8 : April 28, 2018, 05:08:23 »
Inform me if anyone wants me to explain the procedure:)
  • Hyundai i30 2012
  • ro Romania
    Transilvania
« Reply #9 : May 20, 2018, 13:42:53 »
Congratulations for the great job!
For the opening / closing function you explained the cable connection!
Can you explain the camera connection as you promised?
  • 2015 GD 5 Door Hatch, Petrol 1.4, Manual, Blue
« Reply #10 : May 20, 2018, 14:57:55 »
You have to extend the wires from the camera connector to run them from the tailgate all the way to the radio.
The camera wires are coloured so it is easy to install it.
Blue wire: camera power. Connect it on the reverse light. Also because I couldn’t got the signal wire on the radio to work I connected this blue wire in the signal pin hole (position a9 on the radio connector)
Red wire: video out (a15 pin hole on the radio)
Green wire: video ground (a14 pin hole on the radio)
Black wire: camera ground (a5 pin hole on the radio).
This diagram might help you.
  • Hyundai i30 2012
anything
