Author Topic: ROUGH IDLE ............Hyundai i30 crdi blue drive (2013)  (Read 2816 times)
Hi anyone have any idea why my 63 plate i30 diesel has a intermittent idle??
I've sprayed a whole can of EGR cleaner in NO JOY and I've even  disconnect  the  mass air flow  sensor the car drivers slow so connect the sensor back and car drives normal BUT STILL GET THE INTERMITTENT  IDLE . ANY IDEAS
  • Hyundai i30 crdi blue drive (2013)
    Samford Valley
Re: ROUGH IDLE ............Hyundai i30 crdi blue drive (2013)
« Reply #1 : May 12, 2018, 18:50:50 »
mate WELCOME but ; " I have this thing that is possibly string, can you predict the length?"
 Gerard our chief clairvoyant is away meditating, so think about the question and come back with specific info .
eg  KMs , cold or hot, work done by professionals or their advice, and what the **** is intermittent idle? High or low revs or engine dies?
Other symptoms?
« Reply #2 : May 12, 2018, 20:09:59 »
Other symptoms?
Sugar coating is an optional extra..  :snigger:
The more info you can supply the more likelihood of a remote diagnosis. It's difficult at the best of times to diagnose something like this without your head under the bonnet.
« Reply #3 : May 15, 2018, 02:01:40 »
Might sound a bit harsh, but have you tried really trashing it when warm? Many diesels with EGR gets driven way to light & this builds up soot as you already figured out due to use of the EGR-cleaner :goodjob:
Btw. Liquids like EGR-cleaner is not a miracle-thing. If your EGR leaks i would instead remove it & give it a good manual cleaning with a brush & brake-cleaner instead (your intake will probably look the same as the EGR on the inside but thats a major operation)
  • 2016 GD, 5 door hatch 1.6 CRDI 110 BHP, manual, silvergrey
    Samford Valley
« Reply #4 : May 15, 2018, 17:10:02 »
Agreed.
Problem ..... we don't exactly know what his problem was/is????? just guessing.  :)
« Reply #5 : May 17, 2018, 07:57:01 »
Agreed.
Problem: Rough idle. My answer: Experience & a bit of guessing, but thats how kind of all faultfinding works.
    Samford Valley
« Reply #6 : May 18, 2018, 01:12:10 »
Agreed.
 :mrgreen: Will bear that in mind...... if this guy ever bothers to reply, which I doubt.
« Reply #7 : May 27, 2018, 10:34:54 »
2010 I30 fd 240k rough idle at times seems to be due to contaminated fuel, ult bp diesel (highway diesel) from the same servo week after week and occasionally get rough idle excessive smoke on start. usually add 50ml chemtec diesel power plus in the tank clears it right up. the car runs well if the diesel foams when filling but if its flat does not run well. My I30 does not run well on caltex vortex diesel or bp truck diesel, seems to lack power.
