Author Topic: Brake pedal adjustment  (Read 435 times)
    Tasmania
« August 09, 2018, 09:36:59 »
Not sure if this has been asked before, but one issue that annoys me with my new car is the height difference between the accelerator pedal and the brake pedal.
I never noticed it in my old Corolla, but that one's gone to a new home so I can't check it now.
When I slide between pedals I am aware of consciously lifting my foot onto the brake.
On my motorbikes one of the first setup I do is adjust the brake pedal height to a more comfortable level.
Is there any height adjustment on the pedal on the i30?
I imagine the accelerator pedal height would be fixed.
Re: Brake pedal adjustment
« Reply #1 : August 09, 2018, 17:59:53 »
That's interesting I had to go down and look at mine.  :lol:
An easy fix would be to stick something about a centimetre thick to the accelerator pedal. Maybe a piece of high density foam cut to the size and shape of the pedal? Only thing is if you had an accident and they tracked it back to a modified accelerator pedal..  :undecided:
I have some of this stuff lying around. Looks a bit thicker than that one.
:link: Concrete Polyethylene Foam Expansion Jointing - Plain | eBay
Or better still a piece of MDF cut to size and sprayed the same colour as your pedals. You could even cut some grooves in it for grip.  :idea:
  • Use it or lose it!
« Reply #2 : August 10, 2018, 01:51:10 »
You Tasmanians should be discussing adding a second pedal. :lol:
How about investigating remounting the accelerator at a higher level using suitable spacers?
  • Author
    Tasmania
« Reply #3 : August 10, 2018, 02:01:14 »
Is that to counteract our two heads  :crazy1:
Hmm.. remount the loud pedal, not a bad idea.
I dare say I will just get use to it in time, just don't recall the height difference with my old car.
« Reply #4 : August 10, 2018, 04:27:48 »
Some hot laps around Simmons Plains will help expedite the resync between the Brain  and the right foot so you can lose the Oh what a feeling.
  • Author
    Tasmania
« Reply #5 : August 10, 2018, 07:11:28 »
I think you got it right there, it's all in the mind , you know. :snigger:
Don't think they would let an old f*rt like me around Symmons Plains, did have quite a few laps around Baskerville on the Triumph though. :happydance:
« Last Edit: August 10, 2018, 07:17:40 by wooly » »
    Samford Valley
« Reply #6 : August 10, 2018, 19:09:31 »
I'm told every Tazzy home has a tractor (the 2nd car) so why not mount the accelerator on the steering column same as the Fergie and Fordson.
 :snigger:
  • Author
    Tasmania
« Reply #7 : August 10, 2018, 21:12:02 »
 :snigger:
[/quote]
Hey, my first car was a Vanguard with  a Fergie motor in it.
Very agricultural car it was too.
    Samford Valley
« Reply #8 : August 10, 2018, 21:31:53 »
Great cars made by David Brown Co ???? First vehicle I drove ( at circa 6yrs old) was a Fergie tractor. It eventually flipped, as they do, and killed its owner, as they do.
Wooly, We are both dated from here on  :D
  • Author
    Tasmania
« Reply #9 : August 10, 2018, 21:51:20 »
Don't know about Fergie tractors, but the Vanguard was made by the Standard Motor Company in pommie land.
Had a column change and bench seats.
Solid as a brick until they rusted away to nothingness :scared:
« Reply #10 : August 10, 2018, 22:38:49 »
I learned to driver on one.
    Samford Valley
« Reply #11 : August 11, 2018, 00:38:57 »
Fergie and Vanguard had the same motor. Interesting you said it was Standard Co. They made their own cars as you probably know. Also made motors.
When I was a kid we had a six cylinder Standard 20 . It was faster than a Ford V8. Dad used to get Pi$$edof every year when he went to the Post office to renew the rego because they claimed that the model 20 did not exist. He'd drag the idiot outside and push his face down on the car's badge.  :head_butt:
One year the car needed a leaking welsh plug replaced. They degreased the block and up came the name 'Jaguar'.  :victory:
anything
