Author Topic: How to Install a Tweeter for Better Sound Quality - I30 (2007-2012)  (Read 670 times)
  • br Brazil
    Brazil
Hello, My Friends!
I just came here to tell about how I installed a pair of tweeters.
1. Get a pair of tweeters with an integrated case to embed it.
2. Remove the door cover in order to remove the mirror cover
3. Remove the little foam protection
4. Drill a pilot hole with a 1.5mm drill bit at the center (left/up side of the left/bottom square)
5. Just a check the center hole :)
6. Drill a hole with a hole saw or forstner bit (in my case, a 35mm)
7. Check if the diameter has a good fit
8. Remove all left materials
9. Confirm the fit
10. Lock the casing
11. Do it again to the left side :)
12. Connect the cables to the door speaker and cover it with some foam tape
13. Put the mirror cover back, checking if has a good fit and no cables are exposed
14. Very nice :)
  • I30 Top 2.0
Very neat mate and welcome to the club :D
nice, how did you splice into the speaker leads? Any images of that? :goodjob2:
Welcome! Great 1st post! Thanks for sharing!  :goodjob2: :goodjob:
Hello, my friend!!
Sorry... no photos :(
I just split the main cable and soldered new wires with a shrinkable rubber tube.
  • I30 Top 2.0
anything
