Author Topic: i30 PD active LED headlights  (Read 11004 times)
Re: i30 PD active LED headlights
« Reply #210 : September 09, 2019, 17:57:37 »
@BrendonL  looks good.
How did you attach the bulb to the adapter?
Old superglue I just glued the h7 ring to the adapter. I doubt itíll hold for long so I plan on trying some high temp cold weld from supercheap on the weekend.
Loctite 401 or 406 are like super glue but more permanent...  :cool:
Do you think the leds would get hot enough to melt the loctite?
I don't reckon. It's amazing stuff. A mate put me on to it a few years ago and pretty much everything I've ever used it on since has been a permanent repair. It's great stuff.
    East Maitland
« Reply #211 : September 09, 2019, 18:49:55 »
Awesome Iíll get some today and give it a go after work.
  • 2019 i30 go
« Reply #212 : September 09, 2019, 19:03:22 »
I've got the 401 and the 406 (which is supposed to be even better for plastic repair) but I think they are very much the same so either should be fine.
    East Maitland
« Reply #213 : September 09, 2019, 22:46:49 »
I got the 401 Iíll see how it goes this arvo.
  • 2019 i30 go
    East Maitland
« Reply #214 : September 10, 2019, 03:50:14 »
So anyone looking to buy the jw speaker direct fit h7 donít bother those with them already be very careful 1 of my bulbs just died
  • 2019 i30 go
« Reply #215 : September 10, 2019, 04:02:11 »
Faulty , replace or refund from seller.
    East Maitland
« Reply #216 : September 10, 2019, 04:11:35 »
Got them 3 weeks ago off eBay so hopefully the seller will replace or refund them.
  • 2019 i30 go
« Reply #217 : September 10, 2019, 04:38:26 »
Disappointing :disapp: They'll replace them no doubt, there is also a two year manufacturer warranty.
    East Maitland
« Reply #218 : September 10, 2019, 04:45:27 »
I just read that on their eBay listing so Iíll be sending a message soon to get a replacement.
  • 2019 i30 go
« Reply #219 : September 10, 2019, 05:11:06 »
My direct fit JW's turned up this morning so I got straight to it :)
They actually fitted in reasonable easy on the GD using the suitable adaptors :link: 2pcs H7 LED Headlight Bulb Holder Adapter For KIA K3/4/5 Hyundai Sonata 9 | eBay
Only adjustment I had to make was the dust caps, another 2mm clearance and they would have screwed back on with no modifications but luckily I'd thought ahead expecting they would likely require some extra room and had small rubber boots here if needed.
The rubber boot mod would likely be suitable for the PD owners as well, a couple of these boots are what I used :link: 2Pcs 70mm Inner Dia Rubber Housing Seal Cap Dust Cover for Car LED Headlight EB 609876370981 | eBay
Core cut a 56mm hole in the dust caps
Insert the boot into the caps as shown, no glue required as they're a nice snug fit.
Gives me just enough clearance to the fuse box
Installed my Philips T10 LED parkers for a better colour match to the new JW low beams.
Only briefly tested against the garage wall at this stage, waiting for night to roll in so will put another picture up later showing them...doesn't seem to matter which way the bulbs are rotated either from my quick test as the cut off lines are still horizontal.
« Reply #220 : September 10, 2019, 09:26:00 »
Some night shots, levels seem alright so I don't think I'll bother with any adjustments.
They're a little brighter than my halogen Narva Sapphire bulbs and a fair bit whiter.
« Reply #221 : September 10, 2019, 14:59:42 »
Good stuff Craig. Looks like a win to me.  :goodjob:
« Reply #222 : September 10, 2019, 21:55:14 »
@CraigB looks very good.
Are they fitted in a projector housing?
As for my attempts, I haven't had time to try anything in the car.
But I did try a washer alternative - an oblong piece of thin, but stiff, wire. Compared to the washer the chips are further forward and the whole unit is solid. Chip position matches a halogen filament. So the result should be better.
  • 2019 i30 N Line 5 Door Fluidic Metal
« Reply #223 : September 11, 2019, 00:43:37 »
Yes, GDís are projector low beam the same as PDís, they just use a different adaptor.
« Reply #224 : September 13, 2019, 08:00:52 »
Just ordered 2 sets of the direct fit from great wall parts - they accepted offer of $100ea for 2 pairs. May not do any better than $112.50 for one pair but doesn't hurt to try guys.
I just ordered another pair of JW direct fits from Great wall parts, for the high beams this time :)
Price has gone up to $125.99 so I thought I'd give your idea a go and offered $100 and they came back at $105, I'm happy with that :happydance:
« Reply #225 : September 13, 2019, 23:58:24 »
I think I recognise the shopping center roof top pic. haha And the stretch of freeway south with no lights.
The passenger side went in and looked ok first try.
But I've really struggled to get the drivers side to look ok. I've adjusted the bulb many many times. I keep getting dark spots or a strange lit up shape above the cutoff (which also appeared when the halogen were installed).
This is how looks now. The drivers side still has the lit up shape and a dark spot bottom right. I'm not sure if this is an issue.
« Last Edit: September 14, 2019, 00:04:13 by Dantrasy » »
    East Maitland
« Reply #226 : September 14, 2019, 01:51:21 »
I had a dark spot on my drivers side as well. Donít know what causes it yet.
  • 2019 i30 go
« Reply #227 : September 14, 2019, 09:33:45 »
Stockland shopping centre Baldivis, the road picture was on Mundijong rd :)
I hope you get the lights sorted out, I certainly don't have black spots with mine though it is a different model.
Do any of the other N Line owners get that white box above the drivers side cutoff :undecided: looks to be very clean lines, like it's supposed to be there :undecided:
« Reply #228 : September 14, 2019, 21:45:28 »
There are three silver stripes inside the assembly adjacent to the projector lens. My guess is that one of these silver stripes is reflecting the light that creates the shape above the cut off. If you cover the stripes with your fingers the shape disappears. The shape appears with halogens, so yes, it must be a deliberate feature. Still, I don't like it very much.
I can adjust the led bulb so that the shape above the cut off disappears, but the trade off is very bad dark spots, right where the hot spot should be. If I adjust so that the shape is present, the best I can achieve is 'less bad' dark spots. Either way the result against the wall is unsatisfactory and not even worth testing on the road.
« Reply #229 : September 14, 2019, 21:45:51 »
I'll leave the halogens in for now.
« Reply #230 : September 14, 2019, 23:53:18 »
You might see a different result when testing at the correct distance, 7 to 10 meters from a wall works best to see if some adjustments are required to the beam angle.
« Last Edit: September 15, 2019, 00:32:36 by CraigB » »
    Australia, Perth
« Reply #231 : September 16, 2019, 21:49:11 »
Managed to take a quick shot of my PD low beam LEDS from Cherry Tuning down some dodgy back street.  :sweating:
« Reply #232 : September 17, 2019, 00:45:26 »
@Crustycottage Scott the left side of the beams seem extremely high :undecided: also that artefact above the right beam :confused:
« Reply #233 : September 17, 2019, 00:57:36 »
Look fine to me.
Left side is supposed to kick up more.
« Reply #234 : September 17, 2019, 01:09:42 »
Look fine to me.
Not that much, roughly 6 inches above the right beam is where the left should be at 10 meters, the angle of the shot against the corner doesnít give the best view of the left beam though.
« Reply #235 : September 17, 2019, 01:12:59 »
True.
There are plenty of 'how to' guides online that show the correct heights of the beam and at what distance from the wall etc.
« Reply #236 : September 17, 2019, 01:19:13 »
There is a model specific guide on headlight adjustments in the owners manual  :wink:
    Australia, Perth
« Reply #237 : September 17, 2019, 06:40:45 »
@Crustycottage Scott the left side of the beams seem extremely high  also that artefact above the right beam
yes that "artefact" is strange but more like Dantrasy oblong block. I have not adjusted any heights ever myself. However, I did ask Hyundai to ensure they were correctly adjusted at last service in July as even the upgraded halogens bulbs were average on unlit roads.  :crazy2:
Your lights Craig seem bit brighter and more evenly spread.
I don't mind the left beam lighting up the gutter, at least a chance to see drunk pedestrians or kangaroos. will RTFM read the f*cking manual for further adjustments.  :rolleyes:
    NSW
« Reply #238 : September 18, 2019, 04:32:13 »
High beams are in, plenty of room. Low beams, the adaptor (one linked previously suitable for GD) needs spacing - trip to the big green shed tomorrow to suss out a solution.
  • 2015 i30 Tourer CRDi
« Reply #239 : September 18, 2019, 06:18:32 »
Are you sure you've twisted the adaptors far enough to click in? mine were very tight just on the last few mm till you actually feel them click in properly, especially the passenger side as access is much more restricted.
