i30 PD active LED headlights
nogun · 275 · 56121
Offline josh1990
      NSW
The adaptors are flopping around on the bulb itself, not even tried to put them into the housing. Got these adaptors - :link: Pair of H7 Car LED Headlight Bulb LED Adapter Holder LED Adapter Socket Base AZ | eBay
Well they will be loose until they secure into the housing, the problem with the ones you've linked there are that they have no rear upright tabs so you have something to grab onto to twist into place.
These are the type I have, you can clearly see the rear tabs you'll need to be able to lock them in :link: H7 LED Bulb Holder Adapter Base For KIA Sorento Hyundai Veloster Sonata Tucson 9 | eBay
Offline josh1990
      NSW
Ah ok, I see the missing tabs. I'll give them a go even though they're loose.
My JW's for the high beams arrived today, only a quick test up the street at the moment so I'll road test them properly next time I'm doing a night run.
They do seem to throw a good distance, the trees at the end of the street are a good 130 meters away.
Low beam
High beam
Looks good Craig.. The factory LED's in my new car are a highlight. Excuse the pun..
Perfect,  should be able to the reflection of the eyes of all the roadside critters .
Offline BrendonL
      East Maitland
Finally got my replacement h7’s today now I can give them a good few days testing.
  • 2019 i30 go, manual, white
Offline quankino
Narva is rolling out new gen 2 kits. Saw it on SCA sales :link: Narva | Gen II Performance L.E.D Globes and L.E.D Signalling Globes
Good find! Thanks for sharing.  :goodjob:
Offline Georgevagelas
    • gr Greece
      Kavala
Hello! I have read all the posts of this thread and I would like to know if anyone changed alogen bulds to led and is still satisfied without any problems.. Can you please suggest a good set of led bulbs that fit well without any car modifications at pd model? Thank you..
  • i30 fastback DCT
Offline Ohthatsnasty
      Victoria
I have fitted led headlights to my PD SR, i have designed (Extended) and 3D printed my own replacement dust covers if you are still looking?
  • 2018, PD, 5 Door Hatch, G4FJ 1.6T, Auto, Blue
Offline xiziz
    • se Sweden
      Varmland, Sweden
I put led on my high beams a few weeks ago, needed to modify the light housing a little, remove some plastic so the bulb would give the correct light pattern. Very happy with the change, nice, bright and uniform light colour. And it lights up the roadsides a lot better, reach is about the same but much better illumination.
I used Ledson LED 11G Extreme Focus bulbs.
  • Ioniq Electric MY2019 88kw
    • gr Greece
      Kavala
What is your car model mate?
« Last Edit: October 19, 2019, 14:22:30 by Georgevagelas »
  • i30 fastback DCT
    • gr Greece
      Kavala
What is your car madel mate?
I’d expect what’s written in his signature  :)
That's why I asked again because Im looking for information for PD model (this thread is for PDs too)..  Maybe he has two Hyundai models..
« Last Edit: October 19, 2019, 14:31:41 by Georgevagelas »
  • i30 fastback DCT
The Ioniq is sort of a PD i30 with EV or Hybrid drive train, so a lot of shared components. I wonder if one of our Ioniq owners, maybe @xiziz or @Shambles could investigate /compare to see if the headlights are shared.  :cool:
My lamps are single bulb BiXenon with mechanical shutters - the housing is not shareable with the PD series at all.
Offline xiziz
    • se Sweden
      Varmland, Sweden
@Georgevagelas I don't think the light housing or reflector is the same (pd has lens projector high beams I think?) but for the sake of brands that provide a good and legal light pattern it can be helpful to know that the Ledson LED bulbs are the real thing. :)
Housing in Ioniq EV is LED low beams in projector lenses and HB3 9005 Halogens in standard high beam reflectors. (there is a full halogen setup on the base model though).
Cheers guys.. there's my theory out the window..  :spitty: :Pout:
    • gr Greece
      Kavala
I found @xiziz led bulbs :link: LEDSON LED headlight bulbs 11G Xtreme Focus (H7) and they look interesting. Lumiled ZES LED with build-in Canbus, 4500 Lumens, 3 years warranty etc for 110 euros. They offer some bulb holders too. :link: Lamphållare H7 för LED Kia & Hyundai (V1) - Lamphållare för LED - LED - Hel- och halvljus - Diod & Xenon till Bil and :link: Lamphållare H7 för LED Kia & Hyundai (V2) - Lamphållare för LED - LED - Hel- och halvljus - Diod & Xenon till Bil. Which one you think fits at i30 PD (low beams) because none of them refers to i30? Also, bulbs' length is 82mm. Will they fit inside headlights or should I buy new dust covers?
  • i30 fastback DCT
Offline ntebis
      Adelaide, SA
I found @xiziz led bulbs  LEDSON LED headlight bulbs 11G Xtreme Focus (H7) and they look interesting. Lumiled ZES LED with build-in Canbus, 4500 Lumens, 3 years warranty etc for 110 euros. They offer some bulb holders too.  Lamphållare H7 för LED Kia & Hyundai (V1) - Lamphållare för LED - LED - Hel- och halvljus - Diod & Xenon till Bil and  Lamphållare H7 för LED Kia & Hyundai (V2) - Lamphållare för LED - LED - Hel- och halvljus - Diod & Xenon till Bil. Which one you think fits at i30 PD (low beams) because none of them refers to i30? Also, bulbs' length is 82mm. Will they fit inside headlights or should I buy new dust covers?
Δεν έχει ιδιαίτερη σημασία αν δεν λέει για το i30 pd. Σημασια έχει το βύσμα και το i30 εχει Η7, οπότε τα περισσοτερο θα χωράνε. Σίγουρα θα μπορεις να βρεις κατι στο σκρουτζ .
Doesn't matter that they dont list i30, the PD uses the H7 so almost all of them should fit.
  • 2018 PD Active 5 Door Hatch, Petrol 2.0, Auto, Plat. Silver
Offline xiziz
    • se Sweden
      Varmland, Sweden
@Georgevagelas I bought the extended dust covers just to be safe, they are rubber ones that fit outside the grooves. Same store I bought from. :)
Might be some 3D printable ones too if you know someone with a printer.
H7 are centered so only depth should be a possible issue, if you take out one of the current bulbs and measure the distance from the holder to the cap, how far is it? Mine had good clearance on all sides except top because the socket is off center with H3.
Also, don't forget to align the bulbs vertically, makes a huge difference to the light pattern.
    • gr Greece
      Kavala
Hello! I just fit led bulds with external canbus at low beams! I am very satisfied with the result but I have a question. After start/stop the leds are flashing for half second and then back to normal! Is this normal for our car?
  • i30 fastback DCT
Offline xiziz
    • se Sweden
      Varmland, Sweden
I'd guess it's a voltage drop when the engine reignites(as is normal when the load on the 12v rail increases), the Halogens are slow to respond so the slight dimming might not be noticed. LEDs are immidiate so they will turn off if they get to little voltage, if the voltage fluxuates around the minimum voltage of the bulbs they would flash.
Offline Lee17
      NSW
Hi Guys,
I've been searching on google how to swap out the normal lights for a pair of LEDs on my i30 SR PD. But I had troubles trying to fit the LED bulbs into the housing. Has anyone got around to the issue?
  • i30 SR
Offline BrendonL
      East Maitland
You need an adapter to put the bulb in the housing you can get them from online from stedi or iilumo.
Welcome Lee,
A couple of threads you might find interesting. That discuss this issue or include links that do...
:link: LED Number Plate and Interior Lights
:link: PD high beam(HB3's) upgrade query
Offline Tommy369
      Sydney, NSW, Australia
Will they likely run too hot and run the risk of melting the housing? I suspect they pulled that 6000 lumen figure out of thin air however. I plugged them in and they didn't throw up a CANBUS error which is a good sign.
  • PD i30 SR
