Author Topic: screen washer jet replacement  (Read 511 times)
    South Yorkshire
« January 11, 2020, 14:24:45 »
Does anyone know how to replace a screen washer jet, passenger side is fine but the drivers side has pressure ok but spray pattern has gone low
  • I30 1.4 petrol
Re: screen washer jet replacement
« Reply #1 : January 11, 2020, 14:56:19 »
Do you just mean the nozzle?
Is it blocked?
If so then you can either use a fine pin to clear or open bonnet, find where the tube from the bottle joins, separate and blow air though to clear.
Otherwise to remove on my fd and gd they just pull away/out from their seating.
« Reply #2 : January 11, 2020, 15:28:56 »
and if you mean its pointing low stick a needle in it and pull upwards a bit.
« Reply #3 : February 03, 2020, 15:34:10 »
@chrisrounce
Any update?
« Reply #4 : February 03, 2020, 21:47:57 »
  • Author
    South Yorkshire
« Reply #5 : February 13, 2020, 10:54:28 »
I had to purchase a new jet from Hyundai as all on ebay were to small to fit into the plastic top moulding
  • I30 1.4 petrol
« Reply #6 : February 13, 2020, 11:46:28 »
Result and a relative cheap fix.
