Hi All,
I have a Hyundai i30 2008 FD 1.4 for the last 3 1/2 years and I am havin issues with the Power window switch.
Basically about a year ago I replaced the drivers side switch assembley since you would need to press very hard on the button to open and close the driver side window (costs around euro 130) and the issue was partially solved since every know and than it does the fault again but from last week it got worse to the point that I no longer open the window.
I have the same issue again you need to press the power window button very hard to close or open the windows, I cleaned the swithces and checked for any dry joints or loose connections however all seems to be good.
Does anyone had this issue and managed to solve it since I think the issue might be coming from another part maybe the power window motor!
TIA
Matthew
