Author Topic: Hyundai i30 2008 - I want to upgrade my radio  (Read 587 times)
  • wales Wales
    Cardiff
« April 27, 2020, 04:39:48 »
I want to upgrade my car radio to something modern, my car is 2008.  I'm not sure where to start? Is it easy to DIY or get one shop fitted?  I would appreiate any suggestions or some advice from someone who has upgraded theirs.
Steve
  • 2008  5 Door Hatch, Petrol 1.6, Manual, Blue
Re: Hyundai i30 2008 - I want to upgrade my radio
« Reply #1 : April 27, 2020, 20:30:58 »
:link: HOW TO: FD Body - Remove/Replace/Swap OEM (2DIN) headunit
Looks like a lot of fun. If you are just after bluetooth head unit they are plug and play (if you can find one).
  • Use it or lose it!
« Reply #2 : April 27, 2020, 21:27:22 »
So is this (plug and play):
ns
  • ph Philippines
    davao philippines
« Reply #3 : May 10, 2020, 09:53:10 »
you can order an android headunit. im also ordering one for mine
  • first gen i30 2009
« Reply #4 : May 18, 2020, 21:31:53 »
I have upgraded my FD wagon with
Sb Acoutsics SB29RDNC-C0004 tweeters x 2
Sb Acoustics SB17MFC35-4 Midwoofers x 2
Alpine UTE-93DAB head unit single din (plays Flac Files)
JL Audio TWK audio processor
Alpine PDX-F6 150w x 4 amp
Alpine PDX-M12 1200w Subwoofer amp
Subwoofer 2 x Dayton audio RSS265HO-4 10" + 2 x Passive Dayton Audio RSS265-PR 10" in 45 litre box.
I have the same bracket as above except it's for a single din unit (didn't want something flashy)
Wasn't very hard to do , if you search on this forum you will find all information needed to remove the factory head unit and wiring.
Best sound system i have listened to in a car.
  • 2010 FD WAGON ,DIESEL 1.6, AUTO, SKY BLUE
« Reply #5 : May 20, 2020, 15:27:12 »
Well done!  I'd love to upgrade the fairly ordinary stereo in my 2019 Camry but suspect I would be too tight to spend the required  $ to get the result I'd want. I just want a bit more clarity, bass  and volume, although my  new hearing aids have helped a bit!
How much did you upgrade cost Mr X ?
« Reply #6 : May 21, 2020, 16:50:46 »
About $3000
Although i didn't purchase everything at once , it took a couple of months so wasn't too bad.
I'm bit if an audio nut , so the cost is no problem for me.
« Reply #7 : May 22, 2020, 04:29:46 »
Wow! That's probably more than a third of the value of your car. No wonder it sounds good. No criticizing you, it's your money. I'm a tight ass. I wouldn't want to spend more than $1000  to upgrade my Camry Audio and my car is still probably worth $30K.  :-[ so probably wouldn't make enough difference to be worthwhile.
