Author Topic: Car wont start just turn over  (Read 227 times)
« June 29, 2020, 09:00:47 »
Hi my hyundai 130 2.0 diesel has been stalling the last couple of day put a computer on it came up with code po336 which is crankshaft sensor changed it but still wont start so I changed camshaft sensor aswell and still the same problem .I have changed fuel filter aswell to see if that made difference and it didn't. I have tried spraying easy start in air in take. and it will start and run soon as I turn car off  .it wont start just turn over
  • 130 2.0 diesel 140
  • Trans Slender
Re: Car wont start just turn over
« Reply #1 : June 29, 2020, 11:13:27 »
I know nowt, but, if you changed the sensor then maybe that requires an ecu reboot just a thought.  So, have you tried disconnecting the battery for twenty????
« Reply #2 : June 29, 2020, 12:14:00 »
I will try that thanks
« Reply #3 : June 30, 2020, 03:37:14 »
Any RPM reading ?
« Reply #4 : June 30, 2020, 05:55:26 »
Had full diagnostic on it car rpm is ok .it will start and run if you put easy start in air box but  stails after a few miles and wont fire up but will turn over
  • Use it or lose it!
« Reply #5 : June 30, 2020, 06:29:14 »
In an older generation car, I'd be thinking low fuel flow.
« Reply #6 : June 30, 2020, 15:31:27 »
Does it stall when on a sloping road rather than  flat?
« Reply #7 : June 30, 2020, 17:26:08 »
Same applies to later diesels.  Not sure where "2.0 140" sends us........ 2014 2.0 litre CRDi ??  :undecided:
I would be looking into the fuel tank.
Diesel bug?
Blocked or weak primary (tank) pump? ( Pom cars have one, not ours)
« Reply #8 : June 30, 2020, 18:17:08 »
Starts on "easy start" , as in "start ya barstard", or similar ether compound.
Sounds like no fuel flow until it least , idle rpm is achieved.
Low flow due to : pump, shitty fuel and/or shitty filter, slight leak.
« Reply #9 : June 30, 2020, 18:38:26 »
 :goodjob2:
Thats the same stuff.
If it gets to run the HP pump (on motor) must be ok.
The Taco would have indicated if you have RPM = good CK sensor.
Full diagnostic  :happydance: and then what did yoll do? Push it home?
Mate, as Mick and I have said, you have a fuel shortage under the bonnet,
Start where the fuel comes from,the tank.
Given the UK's history on shitty fuel, there is a good chance that diesel bug is fouling the tank pickup sock.
« Last Edit: June 30, 2020, 18:52:12 by nzenigma » »
