Car wont start just turn over
Offline Daniel red
Hi my hyundai 130 2.0 diesel has been stalling the last couple of day put a computer on it came up with code po336 which is crankshaft sensor changed it but still wont start so I changed camshaft sensor aswell and still the same problem .I have changed fuel filter aswell to see if that made difference and it didn't. I have tried spraying easy start in air in take. and it will start and run soon as I turn car off  .it wont start just turn over
  • 130 2.0 diesel 140
I know nowt, but, if you changed the sensor then maybe that requires an ecu reboot just a thought.  So, have you tried disconnecting the battery for twenty????
Offline Daniel red
I will try that thanks
Any RPM reading ?
Offline Daniel red
Had full diagnostic on it car rpm is ok .it will start and run if you put easy start in air box but  stails after a few miles and wont fire up but will turn over
In an older generation car, I'd be thinking low fuel flow.
Does it stall when on a sloping road rather than  flat?
Same applies to later diesels.  Not sure where "2.0 140" sends us........ 2014 2.0 litre CRDi ??  :undecided:
I would be looking into the fuel tank.
Diesel bug?
Blocked or weak primary (tank) pump? ( Pom cars have one, not ours)
Starts on "easy start" , as in "start ya barstard", or similar ether compound.
Sounds like no fuel flow until it least , idle rpm is achieved.
Low flow due to : pump, shitty fuel and/or shitty filter, slight leak.
 :goodjob2:
Thats the same stuff.
If it gets to run the HP pump (on motor) must be ok.
The Taco would have indicated if you have RPM = good CK sensor.
Full diagnostic  :happydance: and then what did yoll do? Push it home?
Mate, as Mick and I have said, you have a fuel shortage under the bonnet,
Start where the fuel comes from,the tank.
Given the UK's history on shitty fuel, there is a good chance that diesel bug is fouling the tank pickup sock.
« Last Edit: June 30, 2020, 23:52:12 by nzenigma »
