Author Topic: Headlight fuse  (Read 465 times)
  • New South Wales
Headlight fuse
« August 31, 2020, 17:46:06 »
Hey guys,
On my way to work this morning I lost low beam headlights, both at the same time!
I had to drive in the dark with my fog lights / high beams when suitable until I had a reasonable spot to pull over.
I can’t seem to find the headlight fuse in the book? 2012 (my13) petrol i30
Thanks, any help is greatly appreciated
  • 2012 Hyundai i30
Re: Headlight fuse
« Reply #1 : August 31, 2020, 18:15:04 »
Welcome Foxo,
It is not impossible that both blew at once, after all they have both had exactly the same amount of use. I'm guessing that you are aware there are 2 fuse boxes. One under the dash near your right knee and the other under the hood. I think in your model that is on the passenger side of the engine bay near the  air clear box. Diesel i30's have been known to be hard on headlight globes for several reasons but the petrol versions not so much.  :cool:
Re: Headlight fuse
« Reply #2 : August 31, 2020, 19:32:34 »
Hey bro thanks for the response
I’m aware of where the fuse boxes are but I can’t seem to find which fuse is for head lights  :head_butt:
  • 2012 Hyundai i30
Re: Headlight fuse
« Reply #3 : August 31, 2020, 20:10:05 »
Unfortunately we don't have a GD i30 any more but hopefully one of our members with the same version as you can check both their boxes and shed some light on the mystery. Just be aware that European built GD i30 tourers for example may have a different fuse box layout than Korean built hatches for example.
    NW Sydney Aust
Re: Headlight fuse
« Reply #4 : August 31, 2020, 23:38:12 »
Just asked Mr G & it looks like the fuse is under dash.
#9 1amp
Headlamp Fuse
Although on another website it contradicts this.
Not sure where now
Re: Headlight fuse
« Reply #5 : September 01, 2020, 00:15:18 »
#9 1amp
Headlamp Fuse
Not sure where now
CHeers Neville, One is probably the Czech built versions and the other from the Korean factory.
I'll have a look at the GD manual in my archive!  :idea: (and edit this post if I find anything)
Well that wasn't much help.. should be marked on the guide in the map of fuses on the inside of the fuse box lid but if it is anything like the manual it will be hard to decipher.  :undecided:
  • Use it or lose it!
Re: Headlight fuse
« Reply #6 : September 01, 2020, 07:10:50 »
If it's like my FD, there are actually two - a high side and low side arrangement - in the engine bay box by the battery.
anything
