Author Topic: Fault code p24c6  (Read 537 times)
Fault code p24c6
« September 06, 2020, 10:37:50 »
Hello and help , got the management light on , not flashing on a 2015 i30 1.6crdi with 35 k on the clock so far I have
Thrashed it and long runs
Cleaned soot sensor
Replaced top temp sensor
Given it a can of dpf cleaner in the dpf and pressure sensor pipes
Checked all connections
Not sure if my cheap reader £20 eBay is clearing the code the light goes off but is back in a few days
Many thanks
Sent from my moto g(6) play using Tapatalk
« Last Edit: September 06, 2020, 10:59:51 by jackodunne1 » »
Re: Fault code p24c6
« Reply #1 : October 15, 2020, 05:57:47 »
The problem was the O2 sensor which is the last  sensor under the car , you have to remove the plastic tray that runs along the r/h side of the car to get to the black box it is connected to ,hope this helps some one
