Author Topic: Broken Wheel/Tire Stud - Front 2012 FD  (Read 490 times)
  • ca Canada
    BC
« April 03, 2021, 20:19:20 »
Hi guys,
Anyone had this issue before?
Changing tires to summers... tire stud broke off.
Does anyone know the stud size  ( front, 2012 FD 2.0 petrol) or part number and if i need to remove the hub to replace it?
Although car has only 60 K wouldnut be easier to replace the entire hub assembly ( i think it comes with studs) rather than  remove and try to replace one of  the studs.
Thank you very much.
« Last Edit: April 04, 2021, 02:10:18 by Endeavor » »
Re: Broken Wheel/Tire Stud - Front 2012 FD
« Reply #1 : April 04, 2021, 16:12:40 »
Try :link: PartSouq Auto Parts Around the World
Enter your car's VIN number and you can find the part number for the hub assembly (which has all the studs fitted) or the stud only. I think you'd have to take the hub off the car so the old stud can be pressed out, and the new stud pressed in. If the stud snapped off because it has been over-tightened at some point, it may be the case that the other studs have been strained so replacing all the studs (or the hub) might be a wise precaution.
« Reply #2 : April 04, 2021, 22:11:26 »
BrendanP, thank you for the detailed response. Very much appreciated.
